OnePlus 8/8 Pro!
zc_squash
I encountered oneplus 7t pro mclaren edition with ghost touch while charging. 1 to 1 exchange as that is not normal. I will avoid that set as i suspect uv glue has seeped into the earpiece already
Regarding export or local, export set is abt 1.1k now, local set is 1298.. so see if u willing to fork out extra 200 dollars for the 1 year warranty here
Gpay issue is the least of your concern as solved after android 11
Posted from PCWX using Pixel 5 Sorta Sage
Hey, thanks a lot. That gives me better context and perspective.
Yeah the seller mentioned about UV glue stain. I suppose you saw the same listing :s13:
KeYoKe
:s13:
Yup i saw same listing. I strongly recommend u avoid that set. UV glue at earpiece is dangerous though, might render local warranty voided as liquid seeped in
stonelips
Anyone got any issues installing/updating certain apps ever since Android 11 update?
I can't update Wild Rift anymore after upgrading to Android 11. It was completely fine before that..
Did all the "delete cache" of Play Store, etc already. Even did a complete factory reset, but still the same. :s22: Worse that after the factory reset, I can't even install Wild Rift anymore.
Dunno what else to do already... looks like I'll just find time to read up on how to downgrade.
Me too. I thought i was alone. Been having problems updating and download large apps.
zc_squash
I see that you are using Pixel 5 from your signature.
How is OP8 Pro cameras compared to Pixel 5? Did you install GCam on OP? Did it give you better results?
Pryson
Guys I used the NFC for payment for train and buses. Scanned and went through for the past 1week. However when I go into my gpay saw those activities by simply go on my bus rides all amount declined. Anyone encountered this?
KeYoKe
Camera pixel 5 wins
Gcam will help a bit definitely but not by much
Posted from PCWX using S20FE Cloud White
louislaw
Hi, found this shop OnePhone selling Oneplus 8 Pro at the cheapest price, $978.
Anyone buy from them before? Is it reliable?
Also, it is an export set, can I use it as per normal like SG set or do I need to flash some rom or something? Never use OnePlus phones before but quite attracted by the specs.
zc_squash
Camera pixel 5 wins
Man... how many phones do you have? :s13: It's S20FE now on your signature. And thought I saw you in the 8T forum too.
Anyone here using OP Wireless charger? How much is it going for?
KeYoKe
:s13:
Changing here and there. Its my hobby
Venkatdommata
Bought from there couple of months ago. Yes export set but with 1 year seller (not official OnePlus) warranty. So far so good.
Upgraded to 11. No issues with GPay in MRT/Bus and shops.
Tormented Soul
Does anyone have trouble updating game apps after having the latest upgrade android 11? Alot of my game apps can't be updated on google play and also oneplus gallery
igarashi
for me i try install some game, after install i cannot start the app.
But some game working ok.
zc_squash
6 months late to the party but I've just got OP8 Pro 🤣
Any recommendations for screen protector? Non-TG type.
Amuroraysg
Yea tried. First attempt worked. But I won’t go saying it’s resolved until it’s consistently working. Let me monitor few more attempts.
Update: tap in and out twice both are working with no issues.
This sound all too familiar...
zc_squash
Need a bit of help with notifications on GMail. Frustrating because it never happened on my OP6.
My emails don't seem to be pushed and I will only see new ones incoming when I launch my GMail app. Are there any settings that I need to enable or disable?
I've already put GMail to ' Not Optimized' under battery settings but doesn't seem to help. Been experimenting a bit and it seems like the only time it works quite consistently is when I also turn off 'Sleep Standby Optimisation'. But I really don't want to turn that off!
louislaw
good to hear that!
so the google services are available out of box?
