OnePlus 8/8 Pro!
doreen27
When ur charge the phone , is it very hot? I feel that mine is quite hot even with all apps closed at background
Chuapl54@gmail.com
Hello, just bought my op8. Anyone knows how do i connect it to my ezlink card to use for bus and mrt? Is it through the ezlink app or google pay?
karloil
Exactly how I'm using mine. I don't use Google Pay. Just install the EZ-Link app and you should be good to go
karloil
Ez link app can link ezlink card to scan via nfc at bus/trains?
Definitely. That's what I'm using.
ETA: Re-read your question again, let me clarify. I'm currently using an NFC Sim - that's what I'm using.
But I just checked EZ-Link app - and yes, you may scan your existing card to the app
kakoutan
Hi my oneplus 8pro seems to be locked at Widevine L3 and I can only view Netflix in SD and not HD mode. Is there a fix for this? Thanks
kid80
Guys,
you can now activate VOLTE without root!
DL Minimal_ADB_Fastboot_v1.4.3 and run the following:
1.adb reboot ftm
2.adb shell
3.setprop sys.usb.config diag,diag_mdm,qdss,qdss_mdm,serial_cdev,dpl,rmnet,adb
4.Open PDC and choose india_vodafone and activate it (as usual guide)
5.adb reboot
Tested working on my OP8P
KeYoKe
Guys,
1.adb reboot ftm
2.adb shell
5.adb reboot
Not working on android 11 :s22:
I shared earlier on ma
Posted from PCWX using Oneplus 8T Lunar Silver
kid80
not sure why it is not working for you but it works fine for me.
Here is a clearer steps.
1.Turn on VOLTE and VOWIFI switch via old logkit
2.Turn on usb debugger on your phone
3. Run this adb command
- adb reboot ftm
- adb shell
- setprop sys.usb.config diag,diag_mdm,qdss,qdss_mdm,serial_cdev,dpl,rmnet,adb
4. follow the steps from 6-10 https://forums.hardwarezone.com.sg/126936937-post1027.html
5.Run this adb command
- adb reboot
6.Go to your Settings Wi-Fi & Internet > SIM & network > SIM 1/2 > Toggle on VoLTE/VOWIFI
KeYoKe
- adb reboot ftm
- adb shell
- adb reboot
just tried. not working PDC is not detecting the phone :s22:
KeYoKe
You watch this youtube.
https://www.youtube.com/watch?v=9E4xuPBnMSY
Same method that i tried.
Just that my phone already have old logkit and engineering mode enabled previously.
Not much info either. Not working on mine, pdc doesnt detect the modem. Shall try it later when im free.
Thanks anyways!
Edit: ok, working on mine already. reinstalled everything and works fine now :s12:
KeYoKe
Hi all, updated my guide to reflect on how to activate volte on Android 11:
Guide to enable VoLTE (Android 11)
1. Download and install these 3 files from the link below:
QPST (Install on PC)
Qualcomm Driver (Install on PC, select WWAN option)
Oneplus logkit (Install on phone)
https://bit.ly/2YUSlZn
2. Install the files as mentioned on PC/Phone
3. Download and install minimal adb fastboot
https://androidfilehost.com/?fid=746010030569952951
4. At phone dialer, key in *#800# > oneplus logkit > Function Switch > Tick "VoLTE Switch"
5. Reboot the phone
6. Go to your Settings Wi-Fi & Internet > SIM & network > SIM 1/2 > Toggle on VoLTE
7. Go to your Settings > About Phone > Tap on Build Number 7 times to activate Developer Options
8. Go to Settings > System > Developer Options > Toggle on USB Debugging
9. Launch minimal ADB and fastboot installed on Step 3
10. Enter the below commands
adb reboot ftm
adb shell
10. Launch PDC Software on your PC
11. Select the Qualcomm WWAN Adapter
12. Right Click "Oversea-Commercial_DS", deactivate Sub0/Sub1 (Sub0 is SIM1, Sub1 is SIM2)
For me, M1 sim is in Sub0, so i only deactivate Sub0
13. Scroll down, and find and Right Click India-VoLTE-Vodafone > Set SetSelectedConfig > Sub0/Sub1
14. Once done, click on the Activate button below to activate the VoLTE Profile
15. Reboot your phone
16. If everything is successful, the VoLTE icon will appear on status bar
Attached the youtube guide as well:
FAQ:
1. Encountered error: "*******connect to device failed
Solution: Search your PC for EFS Explorer (1 of the module from the QPST software installed on Step 1), select your phone from the list and let EFS explorer read the directory of your phone. Then, perform Step 10 to 15 again. PDC will run slow as EFS Explorer is running concurrently with PDC.
The reason for needing to run EFS Explorer to run together with PDC is to allow connection to your phone to set VOLTE profile
2. What happens if VOLTE is gone after an OTA update?
Solution: Perform Steps 9 to 16 again
Disclaimer: Try it on your own risk, dont claim from me if your phone up lorry :s13:
Kitaro9202
Will try again when I got time but when got new update will the volte be gone and need to re enter again?
KeYoKe
Great! you managed to do it.
Yup. Have to reinstall qpst.
I also encounter issue that the pdc cant connect to my phone. Have to launch efs explorer then the pdc can connect to the phone
