OnePlus 8/8 Pro!
oakleyducati
This is standard for any phone using 4g data, because calls come in on your 3g network, the phone needs to switch interface and your data will drop off.
Volte supposed to help with this issue as it makes calls using 4g network instead of 3g, ensuring that your 4g data doesnt drop off while you're making calls as there is no need to switch interface.
Sent from Juno using GAGT
Ooo. thanks for explaining. Haha. So technically I need to follow the steps provided previously in the thread to enable volte since oneplus did not enable this function by default right.
kryptonit3
there would be a volte icon on status bar when it is in use if you are not seeing means it is not enabled
WoShiPro
Anyone got recommendation for loca tgsp for OP8?
Bought 1 from carousell but it seem to be lost in the mail and pending refund now..
jtec14
i found the issue. got to re-activate the full port switch. somehow it was turned off despite i turned it on previously:s13:
Good you got it resolved. Btw i noted the full port switch always revert back to off, believe after restarting the phone.
igarashi
:) Been doing it diligently for my past op devices,even tpg mobile volte is supported after doing the workaround.
So in the steps we actually deactivate oveasea network.
And use India-VoLTE-Vodafone network to be able to use VoLTE ?
dappercivility
I have an item ordered from lazada, ex stock, ordered 7th May, till yest put out for delivery by Simplypost, till today now 1521hrs have not received it. Wonder whats up with delivery couriers....
jtec14
Actually when the workaround first surfaced, the overseas profile are to be deleted and I recalled it came back after OTA and i need to redo the steps.
But to be safe like what bro Keyoke mentioned, just deactivated and activate other country. I have been using India one.
