OnePlus 8/8 Pro!
smallboi09
Hi Bros sorry another question on Google Pay. I can't seem to set up a card for contact less payment. It keeps rejecting my Citibank card. I downloaded the Google Pay Singapore app as bro Keyoke suggested but I am still getting error when I want to set up contactless. Anyone know what's the solution ah? Thanks in advance.
Hmmm I was able to set up my DBS card on Google Pay without downloading the GPay Singapore one leh.
lunzi88
Mine is IN11AA. Just realized the latest OS version available is still stuck at 10.5.1. anyone manage to update their device?
Sent from Samsung SM-G975F using GAGT
I'm currently in 10.5.6. When turn on it automatically asked me to update already
lunzi88
setup is one thing... using it is another. i tried tapping on mrt, google pay cant work. only can work for google pay singapore
There's a separate google pay singapore version meh? I tried checking playstore the only googlepay i found is the one that came with the phone by default
Aikon
Citibank has a limit to the number of times you can register the card to the phone. Check with them if the limit has been reached and they need to delete the previous devices associated with your card before you can add the device.
suxalot
Ahh ok thank you ma friend this was very useful (and the rest who replied too!) Will call them tomorrow.
KeYoKe
Thanks for the input guys. So Oneplus system update are rollout in random batches by default?
yes by batches... can downlod oxygen updater and follow the steps to update
else can download the firmware from oneplus website and upgrade
KeYoKe
https://play.google.com/store/apps/details?id=com.google.android.apps.nbu.paisa.user
dappercivility
One of the OP8Pro user here mentioned disabling ram boost saves battery, I tried for couple of days and yes it does improve battery life by quite abit. For those that does not require high performance can disable the ram boost.
Anything_Whatever
... defeat the purpose of owning a Super flagship phone .... doesn’t it?
dappercivility
Depends on your usage. Battery life with everything on is already pretty good and the ram boost disabled just makes it even better. For my day to day usage, no difference in terms of performance
