OnePlus 8/8 Pro!
KeYoKe
Btw keyoke bro, your volte method works for both dual sim right? Do once both sims auto will have VOLTE?
if need both. deactivate oversea profile on both sub 0 and sub 1. then activate the vodafone profile on BOTH sub 0 and sub 1 bro (step 8 and step 9)
KeYoKe
Reposting for convenience. You may either like my post so u can refer in future or copy paste to a word document
Guide to enable VoLTE
1. Download these 4 files:
QPST (Install on PC) - https://qpsttool.com/qpst-tool-v2-7-474
Qualcomm Driver (Install on PC, select WWAN option) - https://androidfilehost.com/?fid=11410963190603864074
Oneplus logkit (Install on phone) - https://forum.xda-developers.com/attachment.php?attachmentid=4763657&d=1558542807
Oneplus Engineering Mode (Install on phone) - https://www.apkmirror.com/apk/onepl...-0-171117173719-25c8842-android-apk-download/
2. Install the files as mentioned on PC/Phone
3. At phone dialer, key in *#800# > oneplus logkit > Function Switch > Tick "VoLTE Switch"
4. Reboot the phone
5. At phone dialer, key in *#801# > Engineering mode > ON "Full-port Switch"
6. Launch PDC Software on your PC
7. Select the Qualcomm WWAN Adapter
8. Right Click "Oversea-Commercial_DS", deactivate Sub0/Sub1 (Sub0 is SIM1, Sub1 is SIM2)
For me, M1 sim is in Sub0, so i only deactivate Sub0
9. Scroll down, and find and Right Click India-VoLTE-Vodafone > Set SetSelectedConfig > Sub0/Sub1
10. Once done, click on the Activate button below to activate the VoLTE Profile
11. Reboot your phone
12. Go to your Settings Wi-Fi & Internet > SIM & network > SIM 1/2 > Toggle on VoLTE
13. If everything is successful, the VoLTE icon will appear on status bar
Disclaimer: Try it on your own risk, dont claim from me if your phone up lorry :s13:
garychengjw
chaud@sg
Any recommendations where i can get a UAG case for the OnePlus 8 pro?
Sent from OnePlus IN2023 using GAGT
firegazer
Anyone tried their 8 Pro with Google Pay on public transportation? Can't get mine to work.
smallboi09
KeYoKe mentioned some time back about downloading Google Pay Singapore from Google Play for it to work instead. Possibly can try that option and let us know if it works?
