[Ongoing Build Log] Project GeneXis
royfrosty
Introduction
My very first DIY PC back then in June 2013 was an ITX pc. Back then i did nothing but just gaming with an Asus 7750. I started out small and my entire rig was bought from t258jgn.
As i started gaming, the very first thing that came to my mind was the heat output from my GPU. 7750 DCUI was running at 80deg on load. I was thinking of ways on how to cool it down. The single fan and small heatsink would not be able to cool it. Tried various methods on how to cool it. And i found water cooling.
I then slowly move on to bigger stuffs. Bigger, better and performance components. And eventually move on to a beast MSI r9 290 4gb Twin Frozr GPU on Xfire. It is darn hot. And finally decided to WC it.
That's where i consulted Congrade07 on WC and where to start and what to buy.
That's where how i ended up here doing my build log/project GeneXis.
Current Rig Specs
MSI Z87 G45 Gaming + i5-4670k
Avexir Core Series 1600mhz 2x4gb kit white LED
WD Blue 500gb
Samsung EVO 250gb
MSI r9 290 4gb Twin Frozr x2 in XFire mode
Superflower Leadex 1000W 80+ Platinum Fully Modular with white LED
Corsair Obsidian 900D
Asus 16x internal Bluray DVD/RW
Qnix QX2710 27inch A- PLS Panel Overclocked at 96Hz
Things to change
MSI Z87 G45 Gaming ----> MSI Z97 MPower Max AC
Things to do
- Powder coat 900D to white
- Start purchasing the rest of the products by june
- Installation without fittings and tubes
- Plan out on what kind of fittings are needed
- Install fittings with tubes routing
- Air bleed
- Leak test
Things that i have bought
From Aquacomputer.de
Kryographics Hawaii for Radeon R9 290X and 290 acrylic glass edition x2 ~ Euro99.90 each
Cuplex Kryos HF for Socket 1366/1156/1155/1150/775, G1/4 ~ Euro79.90
From FrozenCPU.com
Swiftech 8-Way PWM Cable Splitter - SATA Power x2 ~ USD$10.49
From Amazon.com
Enemrax Cluster Advanced UCCLA12P with white LED x15 ~ USD15.99 each
From Pantip Plaza (Bangkok)
Mayhems Pastel Ice White Concentrate Coolant ~ 800Bhat
Sleeved SATA Cable x3 ~ 160Bhat each
Locally Purchase
Primochill Advanced LRT clear tubing 3/8" 5/8" OD ~ $30
EK x3 250 Reservoir ~ $89
Alphacool NexXxos Monsta 480mm - $182
2m White LED strips with Molex Connectors and crimps ~ $13
Things left to buy
Back plate for kryographics Hawaii R9 290X/290, passive x2 ~ Euro24.89 each
From FrozenCPU.com
Alphacool VPP655 Variable Speed Pump - HF Top Edition - Acrylic ~ USD$119.95
Alphacool NexXxoS UT60 Full Copper Quad 120mm Radiator ~ USD$129.99
Bitspower Adjustable Aqua Link Pipe II (41-69mm) - White ~ USD$14.99
Bitspower G1/4" Mini Valve - Deluxe White ~ USD$25.99
-=Undecided Fittings at the moment=-
From Local
Primer Spray
Sandpaper
Metallic White Spray
As what i intend to do now
I would get my chassis a new make over. Would probably sent in for powder coating.
Few words
Before i could start off on my project GeneXis, i would like to thank a few people in HWC for the effort/contributions and advices given to me.
Special thanks to Congrade07, Op_Valkyrie, zetken, Shadow84, clon22 and others that i have missed out.
royfrosty
I would like to take this opportunity to thank Corbell and Seasonic for the sponsor for the Seasonic Platinum P1000 1000w 80+ PSU. It is of a great honor to have them included into my project log.
allhomme
From Local
Primer Spray
Sandpaper
All these can get from Art friend. They have a lot of other stuff that you may need for case modding. And the spray paints there all quite ah tas wan. so probably last longer than some Flying Eagle brand from China.
Sandpaper they have 500grit to 1500grit.
If you're spraying your entire case, I recommend tearing it down and send it for powder coat. Unless you have experience in spray painting to prevent the paint from getting to thick in some places.
KingJio
All the best! Btw are enermax fans v good cos i seem to see most wc builds using them?
EienShouko
Enermax are decent for the price.
Not really the cream of the crop, like the Noiseblocker and Gentle Typhoons, but those are really expensive vs the Enermax.
Also, pitching tent to see your build too!
The parts you're cooling are very similar to what I'm going to have.
I'm also deliberating between a 900D and Caselabs too!
royfrosty
Thanks for the advise!
Definitely i will take a look into this. Cause this is my first time doing it on a pc. Have done it for buddha sculptures, not sure whether will it be the same.
Would check for powder quote also.
royfrosty
Go for caselabs if you have the money. Heard that their powder coat is good stuffs.
royfrosty
They perform well for that kind of price. They are better and slightly cheaper than Corsair SP120 series.
What i really love about the Enermax fans is,
1. Control speed for Low med high natively example (500rpm-800rpm, 500rpm-1200rpm, 500rpm-1800rpm) They have a dip switch to do the adjustment.
2. The fan blades are able to be remove without dismounting the fan from rads and mount holes. You can wash it easily.
3. White LED has a switch to turn on or off individually.
4. White sleeved cables.
iAmBored
Art's friend spray paints quite ex right?
I get mine from this place. Paints, sandpaper, some drill bits etc..
Sin Bun Trading/Hardware (123, Jalan Besar /62962729)
allhomme
That's why I say the brands there quite ah tas one.
I got a Marabu brand matte black 150ml for S$9.90... Made in Germany and..... I just use it to spray my 5.25 to 3.5in bay bracket.
allhomme
For cases you can consider the Silverstone TJ11 as well. I like their 90deg offset mobo mounting. Won't stress the mobo if you mount multiple gfx card
royfrosty
Hi guys would like some recommendations for places that do powder coat.
I have seen a lot of build logs and tutorials on how to spray paint the 900D and it is discouraging :( there is a lot of corners and things to sand off at the start. So decided to go for powder coating instead.
royfrosty
Thanks Shadow84 for together shared shipping.
All my items till date. 95% complete hoot. Left just fittings, mini valve and a new mobo!
From left to right
2x Aquacomputer Kryographics Hawaii for Radeon R9 290X
1x Alphacool nexXxos UT60 Full Copper Radiator 480mm
1x Alphacool nexXxos Monsta Full Copper Radiator 480mm 80mm THICK!
1x Alphacool VPP655 Variable Speed Pump
1x Alphacool HF Top Edition - Acrylic
3x Black Sleeved SATA Cable
1x EK x250 400ml Reservoir
1x Mayhem Pastel Ice White Coolant
1x Aquacomputer Cuplex Kryos HF CPU Block
2x Bitspower Oring
2x Swiftech 8-Way PWM Cable Splitter - SATA Power
15x Enermax Cluster Advance APS 120mm x 25mm LED PWM Fan White / White LED (UCCLA12P)
1x 3m Primo Advanced LRT tube
royfrosty
Hi guys, need some advice. How much coolant is recommended?
Currently after mixing 250ml concentrate with distilled water 750ml ~ 1L
Is it enough or do i need more?
Yureak
my loop with single gpu + 360 rad and x150 res took me around 1 litre exact. i had to top up slightly with distilled but it doesnt dilute the colour looking good so far
