But if your 970 uses ref board with not much changes to capacitor's height, then should be ok..
lol msi gaming should not be reference board. guess have to wait for the special block from EK. lol
Its close to ref board, but the caps height are raised. So, if get from EK, get the 1 for gaming, instead of ref. it should match... Should ah.. lol..![]()
already emailed EK, they say the msi gaming version should be out within the next 4 weeks!![]()
I am probably gonna try nickel plated. Aqc I will be getting their res, pump and pump adapter. Haha. Shipping cheap ah? Ok shall try. Ppc shipping ex bo? They are cheaper.U might wanna check whether MSI is using ref board and components in the gaming gpu. Whether all dimensions are correct, even for height of caps. If all ok, can consider AQC. Full copper blocks. And their shipping is cheap, even if u add loads of stuff. U can buy ur cpu, gpu blocks from there. Maybe the new rads and some coolant or so.
split shipping siam gst or not?
royfrosty, any space issues with the monsta rad at the bottom ?
Planned to go with 60mm alphacool rad at the top and bottom, but hey if there's plenty of space.
Why not go Monsta![]()
Im usin the Monsta rad at the bottom. Bottom is no issue.
The 60mm or UT60 rad is at the top. No issues.![]()
ok, niceee thanks.
Pardon me, going to pester you for guidance with if I have any more 900D questions![]()
