BBCWatcher
- Jun 15, 2010
Have you tried NFS?BTW, I'm also trying to setup a NAS with another EA8100 on OpenWRT but windows keep giving error but can see the drive.
| Hostname | OpenWrt |
| Model | Xiaomi Mi Router AX3000T (OpenWrt U-Boot layout) |
| Architecture | ARMv8 Processor rev 4 |
| Target Platform | mediatek/filogic |
| Firmware Version | OpenWrt 25.12.6 r33311-981c978eff / LuCI (HEAD detached at 75a306df) branch 26.288.56989~75a306d |
| Kernel Version | 6.12.112 |
| Local Time | 24 Oct 2026, 11:16:34 UTC |
| Uptime | 0h 16m 36s |
| Load Average | 0.26, 0.29, 0.15 |
| Size: 5.12 MiB | Block | OISD - Big | ||
| Size: 2.09 MiB | Block | StevenBlack - Unified hosts |
work ssh root@192.168.32.1
root@192.168.32.1's password:
BusyBox v1.37.0 (2026-10-17 21:45:38 UTC) built-in shell (ash)
_______ ________ __
| |.-----.-----.-----.| | | |.----.| |_
| - || _ | -__| || | | || _|| _|
|_______|| __|_____|__|__||________||__| |____|
|__| W I R E L E S S F R E E D O M
OpenWrt 25.12.6, r33311-981c978eff Dave's Guitar
OpenWrt recently switched to the "apk" package manager!
OPKG Command APK Equivalent Description
opkg install <pkg> apk add <pkg> Install a package
opkg remove <pkg> apk del <pkg> Remove a package
opkg upgrade apk upgrade Upgrade all packages
opkg files <pkg> apk info -L <pkg> List package contents
opkg list-installed apk info List installed packages
opkg update apk update Update package lists
opkg search <pkg> apk search <pkg> Search for packages
For more information visit:
https://openwrt.org/docs/guide-user/additional-software/opkg-to-apk-cheatsheet
root@OpenWrt:~# df -h
Filesystem Size Used Available Use% Mounted on
/dev/root 5.0M 5.0M 0 100% /rom
tmpfs 117.0M 8.8M 108.2M 8% /tmp
/dev/ubi0_2 78.1M 2.4M 71.6M 3% /overlay
overlayfs:/overlay 78.1M 2.4M 71.6M 3% /
tmpfs 512.0K 0 512.0K 0% /dev
root@OpenWrt:~# free -h
total used free shared buff/cache available
Mem: 239540 95504 99124 9016 44912 92500
Swap: 0 0 0
root@OpenWrt:~#
No, Samba and Ksmbd.Have you tried NFS?
@xiaofan I was using the default OS for sharing no issue but wanted to try OpenWrt and so far can't get it to work.I see.
In that case, Adblock-fast should be okay to go, you may need to be careful about the DNS block list used as big can cause issues with both RAM and Flash storage. Use smaller list first to see how it goes.
As for simple NAS function, do not put too much hope on it.
Give NFS a try. Windows ships with an NFS client that you just have to switch on. This PowerShell command should do it:No, Samba and Ksmbd.
Enable-WindowsOptionalFeature -FeatureName "ClientForNFS-Infrastructure" -All -Online
Code:Enable-WindowsOptionalFeature -FeatureName "ClientForNFS-Infrastructure" -All -Online
Hi @BBCWatcher and @xiaofan , thank you for all the help.Maybe you can check out the following to see if they help.
https://github.com/openwrt/openwrt/issues/19204
https://forum.openwrt.org/t/extremely-slow-smb-transfer-speeds-only-on-windows/253723/7
You may want to post your configurations.
Yeah, OK, so try NFS. It’s typically lighter weight and better optimized for the Linux operating systems you’re using. Windows has included built-in NFS client support for eons, so it’s not some alien creature. YMMV, which is rather the point.The drawback is unable to copy large data of files all at once because of the weak CPU and doesn't support double byte filenames due to lightweight Samba implementation.
Enable-WindowsOptionalFeature: Feature name ClientForNFS-Infrastructure is unknown.
ssh root@192.168.20.1
root@192.168.20.1's password:
_______ ________ __
root@OpenWrt:~# apk stats
installed:
packages: 199
dirs: 151
files: 1282
bytes: 33893936
triggers: 0
available:
names: 22487
packages: 11110
atoms:
num: 16223
tmpfs 242.5M 8.0M 234.5M 3% /tmp
/dev/ubi0_2 44.0M 8.6M 33.1M 21% /overlay
overlayfs:/overlay 44.0M 8.6M 33.1M 21% /
Mem: 496724 94072 344688 8192 57964 345456
Swap: 0 0 0
root@OpenWrt:~/ookla# ./speedtest -s 7311
Speedtest by Ookla
Server: M1 Limited - Singapore (id: 7311)
ISP: M1
Idle Latency: 2.41 ms (jitter: 0.15ms, low: 2.09ms, high: 2.46ms)
Download: 1894.37 Mbps (data used: 1.1 GB)
33.41 ms (jitter: 9.92ms, low: 4.34ms, high: 55.91ms)
Upload: 684.16 Mbps (data used: 307.7 MB)
13.69 ms (jitter: 4.85ms, low: 2.44ms, high: 26.22ms)
Packet Loss: Not available.
Result URL: https://www.speedtest.net/result/c/73b7a413-4f85-4791-9284-5b0658a29d02
ookla-speedtest-1.2.0-win64 .\speedtest.exe -s 7311
Speedtest by Ookla
ISP: M1
Idle Latency: 2.51 ms (jitter: 0.58ms, low: 2.25ms, high: 3.20ms)
Download: 1665.89 Mbps (data used: 2.5 GB)
19.90 ms (jitter: 13.83ms, low: 2.40ms, high: 523.23ms)
Upload: 917.64 Mbps (data used: 1.6 GB)
23.75 ms (jitter: 10.21ms, low: 2.45ms, high: 176.74ms)
Result URL: https://www.speedtest.net/result/c/574d5358-d059-4704-b04f-a6a3e314006f
Speedtest by Ookla
ISP: M1
Idle Latency: 3.94 ms (jitter: 0.49ms, low: 3.59ms, high: 5.45ms)
Download: 599.42 Mbps (data used: 775.7 MB)
70.40 ms (jitter: 13.75ms, low: 3.83ms, high: 170.69ms)
Upload: 492.72 Mbps (data used: 563.8 MB)
126.11 ms (jitter: 37.12ms, low: 5.87ms, high: 366.51ms)
Result URL: https://www.speedtest.net/result/c/1333c6de-6cd1-408d-ab4c-607e0cf14231
Speedtest by Ookla
ISP: M1
Idle Latency: 5.46 ms (jitter: 1.86ms, low: 3.65ms, high: 8.11ms)
Download: 139.31 Mbps (data used: 112.1 MB)
30.55 ms (jitter: 10.33ms, low: 9.04ms, high: 87.02ms)
Upload: 106.89 Mbps (data used: 113.8 MB)
98.91 ms (jitter: 37.91ms, low: 9.03ms, high: 267.42ms)
Result URL: https://www.speedtest.net/result/c/8ae72154-a9d4-4360-ab7a-41e28ba77c10
[20:20:36] C:\temp
> dir Z:\windows\Test\
Directory: Z:\windows\Test
Mode LastWriteTime Length Name
-a--- 25/10/2026 3:19 pm 15 test_windows.txt
-a--- 25/10/2026 3:45 pm 1073741824 testfile.dum
[20:20:41] C:\temp
> $item = Get-Item 'Z:\windows\Test\testfile.dum'
[20:20:48] C:\temp
> $time = Measure-Command -Expression { Copy-Item -LiteralPath $item.FullName 'C:\temp' }
[20:21:07] C:\temp
> $TransferRate = ($item.Length / 1MB) / $time.TotalSeconds
[20:21:19] C:\temp
> Write-Host "Transfer Speed: [ $TransferRate MB/Sec ]"
Transfer Speed: [ 253.411791339741 MB/Sec ]
[20:21:29] C:\temp
> rm Z:\windows\Test\testfile.dum
[20:22:41] C:\temp
> $item = Get-Item 'C:\temp\testfile.dum'
[20:23:14] C:\temp
> $time = Measure-Command -Expression { Copy-Item -LiteralPath $item.FullName 'Z:\windows\Test' }
[20:25:03] C:\temp
[20:25:44] C:\temp
Transfer Speed: [ 14.1146651995832 MB/Sec ]
Hi @xiaofan , any idea what I can do with another old EA8100 on OpenWRT?
It could also be used as a dedicated, segregated access point for a guest or "IoT" network — even if you're not trying to extend or improve Wi-Fi coverage. For those purposes you'll probably want to configure a 20 MHz wide channel on 5 GHz. (You'd always do that anyway on 2.4 GHz.) Channel 165 is often a good candidate.2) As an AP to extend wireless network coverage, if you have LAN ports in the rooms
What do I install and which part of the network do I place it in 5)?What is your ISP plan and main router used?
An old Linksys EA8100 running OpenWRT can be used as following.
5) As a filtering DNS server (similar to Pi-hole) to block ads and unwanted websites
More information from official OpenWRT website.
https://openwrt.org/reasons_to_use_openwrt
Adblock-Fast? TIA.
That make sense, as long as the Adblock DNS is sitting anywhere in the same network.Main router (eg: 192.168.50.1) -- EA8100 V1 in AP mode with WiFi disabled, static IP address (eg: 192.168.50.240).
EA8100 V1 running OpenWRT and Adblock-fast and maybe also DNS over HTTPS.
Set the main router LAN clients to use 192.168.50.240 as the DNS server.
