Openwrt Router Firmware
I have upgraded my two OpenWRT virtual instances to OpenWRT 25.12.5 recently.
But I am not doing much with OpenWRT after changing from SingTel 5Gbps plan to M1 10Gbps plan.
For Singtel 5Gbps plan, I bridged two ONR ports and used two instances of OpenWRT 24.10 as the main router for the two independant networks (one connected to the 10Gbe ONR LAN port and another to ONR gigabit LAN port).
For M1 10Gbps plan, I am using TP-Link Archer BE805 as the main router. Currently the two OpenWRT instances are behind the main Archer BE805 router (Double NAT). I will probably change to use one OpenWRT instance as the main router in the near future.
BBCWatcher
Amazon's deep discount storefront woot.com is selling the Linksys AX3200 (a.k.a. E8450) for US$18.99. They're also selling the Linksys E7350 for US$12.99. OpenWrt supports both of these Mediatek-based Wi-Fi 6 wireless routers. The E8450 has twice the RAM and a faster processor while the E7350 may have a faster USB port and supports 802.11ax on its 2.4 GHz radio.
Be sure to include Woot shipping costs (if you're not an Amazon Prime member) and ezShip costs (including 9% import duty) when considering whether these routers are good values.
On edit: From what I've read it can be tougher to get OpenWrt installed on the Linksys E7350. Also, these two models pop up on Carousell from time to time, so you might be better off buying locally.
hwzlite
BBCWatcher
I note that the Gemtek/Quantum MXF-W1700K is available on eBay for as little as US$50 now, plus ezShip and import duty.
One eBay seller is offering the similar model Brightspeed XR1710G for US$99 plus shipping, and it has OpenWrt already installed.
hwzlite
Woohoo, another good weekends homelab project to dive in!
NetPulse, a 100% free and opensource NOC for OpenWRT​
WaterDrinker
see
seeing cheapest at US$90+
BBCWatcher
how hard is flashing OpenWrt on it?
Really easy if someone has already done it, as one eBay seller had. Fairly difficult if not since you need a USB to serial adapter and some greater technical proficiency. There’s some discussion in this forum and elsewhere about doing it, including step by step instructions with photos.
Trying owut upgrade with OpenWRT x86_64 VM under PVE 9.2.20.
https://openwrt.org/docs/guide-user/installation/sysupgrade.owut
https://forum.openwrt.org/t/openwrt-x86-upgradability/254291/14
The upgrade from 24.10.2 to 24.10.8 got no issues.
The upgrade from 24.10.8 to 25.12.5 got one issue and then need to remove one package and use the "-force" flag because of packages downgrade.
Bash:
root@openwrt18:~# owut check --verbose -V 25.12.5
1 packages missing in target version, cannot upgrade
4 packages were downgraded
284 packages are out-of-date
Automatic package replacements/removals:
  Package                             Replaced-by
  opkg                                apk-mbedtls
Details at https://sysupgrade.openwrt.org/json/v1/overview.json
Default package analysis:
  Default                             Provided-by
  dnsmasq                             dnsmasq-full
  nftables                            nftables-json
There are currently package build failures for 25.12.5 x86_64:
  Feed: packages
    1 unshown
  Feed: telephony
    1 unshown
  Feed: video
    10 unshown
12 package build failures don't affect this device, details at
  https://downloads.openwrt.org/releases/faillogs-25.12/x86_64/
ERROR: Checks reveal errors, do not upgrade
root@openwrt18:~# opkg remove  luci-app-nft-qos
Removing package luci-app-nft-qos from root...
owut - OpenWrt Upgrade Tool 2026.07.08~db17536e-r2 (/usr/bin/owut)
ASU-Server     https://sysupgrade.openwrt.org
Upstream       https://downloads.openwrt.org
Target         x86/64
Profile        generic
Package-arch   x86_64
Root-FS-type   squashfs
Sys-type       combined
Version-from   24.10.8 r29233-443ec4032a (kernel 6.6.144)
Version-to     25.12.5 r33051-f5dae5ece4 (kernel 6.12.94)
Build-commit   https://git.openwrt.org/?p=openwrt/openwrt.git;a=shortlog;h=f5dae5ece4
Build-FS-type  squashfs
Build-at       2026-06-29T12:59:20Z (~103 days ago)
Image-prefix   openwrt-25.12.5-x86-64-generic
Image-URL      https://downloads.openwrt.org/releases/25.12.5/targets/x86/64
Image-file     openwrt-25.12.5-x86-64-generic-squashfs-combined.img.gz
Installed      347 packages
Top-level      113 packages
Default         44 packages
User-installed  77 packages (top-level only)
283 packages are out-of-date
  Package                             Replaced-by
  opkg                                apk-mbedtls
  Default                             Provided-by
  Feed: packages
    1 unshown
  Feed: telephony
    1 unshown
  Feed: video
    10 unshown
WARNING: Checks reveal package downgrades, upgrade still possible with '--force'
root@openwrt18:~# owut upgrade -V 25.12.5 --force
Target         x86/64
Profile        generic
Package-arch   x86_64
There are 0 missing and 2 modified default packages
Request hash:
  fd9d2ebc8fff004ebc2ed36ebc7d8ccc9e2a006faae725947f992a8241225514
Status:   queued - 0 ahead of you
Progress:   0s total =   0s in queue +   0s in build
Status:   container_setup
Progress:   2s total =   0s in queue +   2s in build
Status:   validate_manifest
Progress:  34s total =   0s in queue +  34s in build
Status:   building_image
Progress: 398s total =   0s in queue + 398s in build
Status:   done
Progress: 402s total =   0s in queue + 402s in build
Build succeeded in 402s total =   0s in queue + 402s to build:
Image saved : /tmp/firmware.bin
Installing /tmp/firmware.bin and rebooting...
root@openwrt18:~# Connection to 192.168.60.1 closed by remote host.
Connection to 192.168.60.1 closed.
root@debian13ct13r1:~/ookla# ssh root@192.168.60.1
ssh: connect to host 192.168.60.1 port 22: No route to host
root@192.168.60.1's password:
BusyBox v1.37.0 (2026-10-07 00:35:53 UTC) built-in shell (ash)
  _______                     ________        __
 |       |.-----.-----.-----.|  |  |  |.----.|  |_
 |   -   ||  _  |  -__|     ||  |  |  ||   _||   _|
 |_______||   __|_____|__|__||________||__|  |____|
          |__| W I R E L E S S   F R E E D O M
 OpenWrt 25.12.5, r33051-f5dae5ece4 Dave's Guitar
 OpenWrt recently switched to the "apk" package manager!
 OPKG Command           APK Equivalent      Description
 opkg install <pkg>     apk add <pkg>       Install a package
 opkg remove <pkg>      apk del <pkg>       Remove a package
 opkg upgrade           apk upgrade         Upgrade all packages
 opkg files <pkg>       apk info -L <pkg>   List package contents
 opkg list-installed    apk info            List installed packages
 opkg update            apk update          Update package lists
 opkg search <pkg>      apk search <pkg>    Search for packages
For more information visit:
https://openwrt.org/docs/guide-user/additional-software/opkg-to-apk-cheatsheet
BBCWatcher
The OpenWrt community has released OpenWrt Version 25.12.6. There are several important security fixes in this release for potentially remotely exploitable vulnerabilities, so please update as soon as reasonably practical.
This release also includes some "out of the box" Wi-Fi device compatibility improvements, support for several new devices including the Cudy WR3000U v1, and many device-related fixes.
Upgrading from OpenWRT 25.12.5 x64 VM to 25.12.6 using OWUT is pretty smooth with all the settings remaining intact and the few things I checked are still working (DNS over https, Adblock-fast, DuckDNS DDNS and Wireguard VPN server).
windwaver
Early this week I noticed that adblock-fast package was not blocking ads properly.
Checking out the forum and seems to be a common problem. Luckily upgraded to the latest version fixed the issue for me.
Reference from OpenWRT forum.
https://forum.openwrt.org/t/adblock-fast-ad-blocking-service-for-dnsmasq-smartdns-and-unbound/170530
OpenWRT project has the following packages for ad blocking
https://openwrt.org/docs/guide-user/services/ad-blocking
1. Adblock
2. Adblock-Fast
3. Adguard Home
4. Adguard Lean (no official package yet).
You can of course use Pi-hole or standalone Adguard Home installation.
I was using Pi-hole LxC container with OpenWRT for quite a while, then I switched to Adguard Home LxC container. But later I become lazy and just use Adblock-Fast package.
@xiaofan , which of the ad block package above is easy to manage and good?
Thinking of installing, TIA.
What is the OpenWRT router you are using?
If you are new to OpenWRT just go with Adblock.
I like Adblock-fast as it is leaner.
Adguard Home is more advanced.
I do not use it inside OpenWRT but rather I have a few dedicated Linux LxC contains with Adguard Home (or Pi-hole) to use with my TP-Link Archer BE805.
windwaver
@xiaofan Good old EA8100, does it take up a lot of memory?
BTW, I'm also trying to setup a NAS with another EA8100 on OpenWRT but windows keep giving error but can see the drive.
I see.
In that case, Adblock-fast should be okay to go, you may need to be careful about the DNS block list used as big can cause issues with both RAM and Flash storage. Use smaller list first to see how it goes.
As for simple NAS function, do not put too much hope on it.
