- Jul 14, 2005
Does it have the function for dual apps?
oppo calls it clone app
I came from Huawei P30 Pro... you know, the battery beast they say. I switched to Oppo Find X2 Pro because P40 Pro doesn't have GSM and my work requires lots of Google apps. So, here's my short summary:
1. Form factor - equivalent to Huawei, if not better (e.g. refresh rate)
2. Battery - it can easily last 2 days for moderate users. but if your SOT is more than 5 hrs a day then maybe you'll need to charge every night.
3. Charging - hands down this phone's charging (65W) is godly.
4. Color OS - as this is my first Oppo phone, I actually find it nice, similar to Huawei
5. Camera - equivalent, or better than P30 Pro. but it doesn't have 'Moon' mode so you can't zoom in to see the surface of the moon. Other than that, it's snappy, sharp and colours are nice.
It also has all the friendly features like double tap to wake, AOD, it's IP68, supports Aptx audio codec, seriously massive storage space and more than enough RAM. almost every spec is high-end (Bluetooth 5.1, UFS 3.0, Wifi 6, etc.).
so far I only have an issue with OCBC app where sometimes when it loads, it's a black screen. idk why...
Just to weigh in on the OnePlus 8 pro vs Oppo Find X2 pro comparison.
Fyi, I got my Find X2 pro through telco; can't see myself paying $1699 for it. I'm actually in the other thread as well, to see if I want to switch to OnePlus 😅
So, I'm not a camera person, hence, I look out for the other tangible aspects.
1. 65w vs 30w charging. Granted that Find X2 pro doesn't have wireless charging, but the fast charging is insanely... well, fast. It'll be over even before you know it. If wireless charging is not crucial, then the 65w wins hands down.
2. Ceramic/vegan leather vs frosted matte glass back. This will be down to personal preference. I tend to use phone without a case, so the feel of holding and using it is important. The matte glass back some say it's slippery, some not. The vegan leather definitely is good for caseless use.
3. Color vs Oxygen OS. I had used OnePlus phones previously; there is nothing to dislike about Oxygen OS. Color OS has really come a long way, much better than I last used an Oppo phone. In fact, I appreciate that it has AOD, gestures when display is off, and even to swipe left to delete a message (similar to IOS). I install 3rd party launcher, so the stock is not relevant to my usage. Battery is good, and notification comes in promptly as well. Thank God there are lesser restrictions now in Color OS; able to activate developer options and accessibility modes to further enhance user experience.
So, all in all, it depends on one's personal preference, I guess. Cos hardware wise they are really similar.
Looks like I'm holding onto Find X2 pro then 😂
Posted from PCWX using CPH2025
Your sharing is timely. I have the oneplus 8 pro and I am looking to get the Find X2 Pro as an additional phone. Would both phones be too similar? I like that oxygen os can use icon packs on the playstore. Color OS has themes similar to Huawei right? Or can color os install icon packs on playstore too?
interesting you came from p30 pro and you said the battery life is almost the same?.. i'm using p30 pro too, and other p30 pro users said moving to find x2 pro the batt life is far inferior.
on p30 pro i can have 6-7 SOT sometimes and still have 20-30% battery life remaining (this is a 1 year old phone also)..
This is the reason why i went Mi 10 Pro instead..
The above is from stock launcher, so I believe the icon pack option is quite limited (others please correct me if I'm wrong). The theme store has wallpapers, fonts and themes, but I don't see icon packs there. So, likely the icons will follow whichever theme you decide to go with. Btw, Oppo seems to have lesser content in their theme store compared to Huawei (personal perspective).
The other reason I'm not very sure about icons in stock launcher, is because I usually use smart launcher. It's highly customizable and suits my needs, and of course can install icon packs of choice from play store. So, if you use 3rd party launcher, can work around the icon pack issue.
And yes, and reading up and doing comparisons, both phones are basically 'cut from the same cloth'. Like some bros mentioned earlier, if you want better camera or bigger storage, can consider the Find X2 pro. But really, the hardware is really sama sama, down to the camera notch display.
In fact, I had just ordered the OnePlus 7 pro (Lazada got promo mah) instead of 8 pro as additional phone, cos firstly it's $550 cheaper to have joy of using Oxygen OS, and secondly I felt both Find X2 pro and 8 pro are just too similar. Heh, at least the 7 pro is full screen
Anyone with s20 plus and this phone? Which has better baty life?
Then this phone resolution can down to 1080 with 120hz?
If u are talking about local set s20+ with the crap exynos processor, this wins it by miles. 6hrs sot for this phone vs 4.5hrs on local s20+
Truth be told i really have no clue if the battery life will be good. Because the capacity is not high. Will be good if someone can tell me full hd at 120hz, SOT is how long.
Been using Find X2 Pro for abt 1 mth.my starhub contract is up thinking should i get this Find X2 pro, Galaxy note 10+ , S20 Ultra or OnePlus 8 Pro ?
Samsung Any other issues / review ?
