OPPO R7 Plus
jazzman80
At least get a 5.5 inch or 5.7 inch screen size will be good enough...depending on how the mobile phone company make the screen appearance........
just saying,
r7 plus;
158 x 82 x 7.8 mm
6.0 inches (~76.6% screen-to-body ratio)
iPhone 6s Plus;
158.2 x 77.9 x 7.3 mm
5.5 inches (~67.7% screen-to-body ratio)
just like r7 plus is as tall as iPhone and bigger too.
but the screen to body ratio is 8.9% higher.
based on an ideal 5.7“ with high STB ratio, note 5 has 75.9%
Mate 7 and Samsung A8 on 4G max i hit 7hours SOT already kichia :s13:
R7+ is indeed slurpee. Always looking for battery monster :s22: but this brings it to a whole new level.
i wanted to buy mate 7 again but the standby not as good.example 8hrs overnight standby, drop like 3-4% battery.
ever considered A8 and meizu pro 5 but i don't like the physical home button.
standby of r7+ is good, max 2% drop in the 8hrs?
personal usage 65hrs standby with 15hrs SOT.
standby can be longer but i always meddle with the phone,can't resist the beauty.:D
jedi5diah
mi note is
5.7 inches (~74.4% screen-to-body ratio)
155.1 x 77.6 x 7 mm, 161 g
jazzman80
mi note is
got considered it before but battery life not as good.
my criteria to keep a phone;
1. great battery with good standby
2. not thicker than 8mm body frame
3. no easily heat problem
4. good audio quality
new criteria;
high screen to body ratio around 75% (it equates to thin bezel too)
:s22::s22::s22:
jazzman80
a problem arises again,
the android OS component is waking up the phone now and then.result battery depletes when the phone is left on standby.
need to find out why.
edited: just shut down and power on the phone. restart no use.
walkofwinners
did you install any new apps recently?
TheHome
Been using the R7 Plus for a week now. Everything's good so far. It's just I can't seem to find any nice cases around, even online. Anyone managed to change to a new case other than the case provided by Oppo? :)
garychengjw
try taobao. :)
jedi5diah
use google translate, lots of goodies and don't use alibaba more ex but the same sellers
jazzman80
im giving up this phone already....
all blame it on lollipop android os. keeping the phone awake constantly. reverting to kitkat probably...
amazingone
Color OS 3.0 coming soon ~
Sent from my Rice phone using GAGT
jazzman80
as long as the android os wake up issue is not solved, it's the same.
unless you are using 4G network.
2G/3G triggers the wake up.
jazzman80
Can you explain what are the systoms of this wake up issue?
battery depletes at least 1% every hour or so when you think your phone is on deep sleep.
just look at your battery usage. settings > battery, explore around.
access into "android OS" and don't be surprised by the period of wake up.
it should be on top of the list instead of "display/screen on".
you can try connecting your phone to 4G, that might stop the wake up. but the battery still depletes on the other hand via LTE.
unfortunately, i think marshmallow does not resolve such issue too. would confirm again if there's chance.
gkotody
Thanks for the explanation.I don't seem to have this issue.Battery life is super.Average is 2 days.On 2 occasions, I got 3 days usage.Light user with WA, a few calls & FB.
jazzman80
amazing. can screenshot your battery usage and upload here?
walkofwinners
Decided to jump on the bandwagon and try out the r7 plus. So far so good.
Any way to enable multi user ?
