Oppo R9
NoHomoBro
guys I got 2 set of oppo r9 plus up for sale. 1 is unsealed for testing another is sealed set, both are local telco set. looking for around $666 interested pm or sms me at 9 six 5 5 eight seven 1 9
sbu7360
anyone still have notifications issue?
my watsapp everytime no notifications.. went down suntec to update latest version still cant get...
Sian!
rubbadubbaducky!
Is the IMEI shown on the R9 box? Or must I unbox the phone, enter the code?
I want to check if its a legit set before handing the seller cash.
P R N D
Just to add.
P9 is Huawei flagship phone, using their top of line in-house CPU.
R9 using cheap mediatek chip.
amazingone
OPPO Taiwan will be updating the F1s, R9, R9 Plus to Android 6.0 soon!
Along with the update, they will be updating it with the 4G+3G dual SIM feature too!
Will OPPO Singapore release this major update for the F1s, R9 and R9 Plus too..?
Sent from an Xperia using GAGT
amazingone
OPPO Singapore will also be updating the R9, R9 Plus and F1s to support 4G+3G too!
OPPO Singapore said:
http://www.oppo.com/sg/supports/announcement/test
Software to support dual SIM functionality is now available for R9 Plus
All three carriers in Singapore cease 2G services effective from 1 April, 2017.
We are pleased to announce that a new software is available for OPPO R9 Plus to support dual SIM functionality.  After the successful upgrade, your OPPO R9 Plus will allow dual SIM with 4G+3G compatibility.
And software for R9 and F1s is coming soon...
【Software download link】
【R9 Plus】http://downloads.oppo.com.s3.amazon.../X9079EX_11_OTA_001_all_201703111638_wipe.zip
Below are the instructions on how to upgrade.
Upgrade instruction:
【Before you upgrade】
- Make sure to back-up your data before you start the upgrade as all data will be wiped in the process.
- Make sure there is more than 40% battery.
- Make sure there is at least 1.5GB free storage space on the phone or micro-SD card to download the software installation package.
- The whole process of installation will take some time, please do not do other operations or power off your device during the installation process.
【Installation Steps】
1.       Download the software package which correlates your model (R9 Plus, R9 or F1s) to the phone storage’s (or SD card) root directory (ie not in any sub-folders).
2.       Go to Files – All files – (click SD card if you have downloaded the package to SD card) – select the zip file – Click Update now. (Figures below are shown as an example of SD card).
3.       Your device will then reboot and display the progress of upgrade (see figure below), which will take some time.  Please do not do other operations or power off your device during the process.
4.     After the progress bar is complete, the phone will reboot and remain on the OPPO logo for 3 to 5 minutes. Please do not power off the device as this is normal.
5.       Once the phone is fully booted up, the standard start-up guide will show up to setup the language, region and Wi-Fi.  Upon completion of the guide, please check Settings – Dual SIM and mobile network – Preferred network type, and make sure you have selected 4G/3G/2G (Auto) as Preferred network type.
6.       And by now, congratulations, you have successfully upgraded the software.
