PC Build Recommendation ~$3k
EJB
Which chassis? $249 as mentioned by TS? There are chassis over $800.
I know there is, but for mATX there are many options and nice looking ones with cable management features. I can find nice ones for <$50. $249 is overkill, just MHO.
EJB
Thanks for the inputs. I chose the case cause it comes with a controller and ARGB fans, which would give some RGB lights to the case, as my friend would like some RGB lights in the rig. The case is also rather compact, as compared to a full tower and cleaning (of dust filters/vents) looks to be easier.
I need to clarify that PC Themes did not recommend the parts; I chose the parts myself and took the price from the pricelist. I will consider replacing the stock cooler too.
You can look at Tecware (https://www.tecware.co/nexusm). They have mATX and is small and nice also, you get a set of orbi fans (3 aRGB+controller) also won't need $249.
Some even come with the aRGB/RGB fans. Additional aRGB fans also won't take up $200 with a controller. I sold the fans that came with casing for $20 and replaced with white LED CM 120mms.
$249 is a bit expensive IMHO. There are better places to spend that kind of money. Like a larger NVME and forgo the 1TB HDD? You can go for the RTX3060 also.
chenghui
Mobo + Processor: Asus TUF Gaming B550M with 5600X - $696
Casing: Asus TUF 301 - $49 (PWP)
PSU: Corsair RM750W Gold / Seasonic GX-750W Gold - $173 / $175
Ram: Corsair Vengenace LPX 3600 CL18 8GB X 2 - $129
GPU: Palit RTX 3070 Gaming Pro OC - $818
SSD: WD Black N750 500GB/1TB - $153 / $175.17 (Amazon.sg)
HDDISK: WD Blue 1TB - $58
Cooler: CM Hyper 212 Red / ID Cooling SE-224-XT - $39
Total: $2115 (5ooGB SSD) / $2137.17 (1TB SSD)
Can be cheaper if you wait for 12/12 to purchase the PSU/RAM/SSD. Price above from PCThemes. Windows 10 key just get online.
Here's my take;
CPU+MOBO :5600x + B550m Steel Legend 664$
SSD: Buy from Amazon.sg Crucial P5 nvme ssd for 160$
PSU: SEASONIC FOCUS GM-750W SEMI GOLD 7YRS 159$
Ram: 3600mhz CL16 RGB Crucial Ballistix 8gbx2 for 120$ @amazon.sg
GPU: RTX 3070 palit gamingpro 818$
CPU cooler not necessary but if you need get a cheap one like 212.
Casing: Ask him to choose. If not P400A/P500A, Meshify, Lancool ii mesh, TD500 ~150$
Windows, don't buy. Use unlicensed or go online and find. Around 20-30$ can get OEM keys.
Total: 2071 @ pcthemes and amazon.sg
After you buy monitor ~500$, keyboard and mouse (got razer bundle get cynosa, kraken lite and razer viper for 170$ at popular) got leftover upgrade the card to RTX 3080
Thanks guile and skrekro for the build recommendations! I will take them into consideration. I think I would be considering getting SSDs from online shops instead, to save cost.
chenghui
You are right, I decided to look at other options (e.g ATX) too such as the Phanteks P400A and ASUS TUF 301 suggested earlier. However, I would need to see if my friend likes the other casings. I took a look at other Tecware cases and they look good too. Thanks!
shadow84
Tecware cases are mostly modified copies of popular models in the market. Low price but feels cheap, u get what u paid for anyway.
But for a cheap case, nr400/nr600 should fit the bill cab get below $100 during 12.12 if u diy.
skrekro
Ditto. I'd stay away from tecware cases unless you really like the look or really don't care. Feels cheap, bad QC, form over function. For a bit more, can get ones from more reputable brands. Built like 3 for my friends and hated it.
EJB
I took the Evo Nexus which is ATX. The front to squeeze 3 fans is a bit tight.
EJB
QFT.
It's cheap but good, honestly, at $70 for a ATX casing vs what I was looking for out there, I think I'm okay, my last casing has no cable management + tonnes of 5.25" bays, so decided it's time to change.
It's pinoy brand, so... but oh well it's compact and nice for my ATX board, I've no complains.
NightRaven49
please dont use the nexus m with any kind of dedicated graphics card, airflow is straight up trash. source:
am using it -->​
but yes the cm nr400/600 are good budget options. the silverstone ps15-rgb is another good matx case with 3 included fans.
Navillera
I bought tecware VXR white and personally find it nice and no complaints
Posted from PCWX using iPhone13,2
majora
This was what I understand when I WA and PM PC Themes, but have to be Asus Motherboard and AMD CPU according to Asus Promo. You can double confirm with PC Themes before going down.
If you prefer other casings than can go for cheaper similar performing other brand motherboards like the Asrock.
Ah i see.. thanks :)
DefinePro
I'm using tecware forge m black casing too. Tbh, the quality is actually ok for a sub $70 case. The hinged door with tempered glass is really nice too. It just looks compact and handsome imho, and the holes are relatively easy to access if you're gonna diy. The only worry that I have is actually the dust build up on the mesh after awhile I guess...
EJB
am using it -->​
I'm on Nexus Evo, if only the front can do 3 120mms. Am going to try to fix in 3 soon, now on -ve airflow, 2 in 3 out (rear+2 top).
The side dust filter helps in dust trapping, I also added my own dust filters + magnetic strips on them so I need not screw it on and easier to remove to dust.
Price wise, honestly at $70 (-$20 for the fans) is quite worth it. I'm also using a tower cooler. It can fit.
shadoweez
Ryzen 5 5600x Build
hi everyone,just want to share my build (since October)
Ryzen 5 5600x ($489) Carousell
Gigabyte B550M Auros Pro-P ($184.98) Amazon,SG (can update bios without cpu for zen3)
Corsair Ballistix Rgb 3600 mhz 32GB (2x16) ($235) Carousell
MSI RTX 3070 Ventus 3X ($794.53) Amazon.SG (Shipped on 16 DEC)
Cooler Master 212 Evo ($36.30) Amazon.SG
Seasonic Focus GX-750 80 Gold ($164.00) Shopee
WD SN550 NvMe SSD 1TB ($128.00) Amazon.SG
Fractal Design Meshify C TG (146.00) Shopee
Total $2177.81
Everything assembled just waiting for my graphic card from Amazon.
Mr BBFA
got any specific dust filters to recommend? where did you get them from?
goodchong
sharing my built
CPU: AMD Ryzen 5 3600
MBD: Asrock B450M Steel Legend
PUS 650W 80+ Bronze
ATX casing
( S$430 )
RAM: 32GB DDR4 3200Mhz- ( S$120 )
SSD: Adata XPG SX8200 Pro NVMe PCIe M.2 1TB - (S$137)
GPU: ZOTAC 3070 Twin Edge OC local set - (S$879)
Monitor : Xiaomi 34 inch ultrawide 144hz - ( $445)
Total damage is S$2011
-Synchronicity-
sharing my built
PUS 650W 80+ Bronze
ATX casing
( S$430 )
That's damn good price for the SSD. Can share what brand and model for the following too?
1. PSU
2. Ram
goodchong
1. PSU
2. Ram
Adata SSD can get from Taiwan seller. Very impressive writing and reading speed , coming from a previous user of SATA SSD
https://shopee.sg/product/285393993/3857805949
Can't remember the PSU as it's a bundle
RAM -
G.skill F4-3600C18-8GVK 3600mhz CL18 8GB x 2
Klew KD48GU881-26N190A 2666mhz CL18 8GB
G.skill- F4-2666C19-8GNT 2666mhz 8GB
Overclock RAM to 3200mhz so far is okay
-Synchronicity-
RAM -
Thanks for the link. Gratz and enjoy :s12:
EJB
I bought a 120x120mm 5 pc set from taobao. Then I got 1m of magnetic tape, pasted 2 strips on 1 side of the filter, then overlay on the fans behind the front vents.
I put 3 pieces infront of the Nexus Evo although I only have 2 fans. Once my 1TB M.2 comes, I will remove the SSD holder and should be able to squeeze in another 120mm fan to balance the airflow.
