Mine cannot, everything is quite dustyI remove from the case and vacuum whenever I do a rebuild, maybe every year or two.
Just did that couple of days ago and the fans were not really dusty. I suppose most of the dust have been caught by the air flow slits on the casing.
i just did my cleaning 2 weeks ago. I removed the screws, took out the fans for easier cleaning.How does everyone clean their fans ar?
I generally take a damp coth and use index finger slowly wiggle the blades one by one
Tedious process
I only removed my 2cpu aircooler fans to cleani just did my cleaning 2 weeks ago. I removed the screws, took out the fans for easier cleaning.
Use cloth to wipe down the dust.
me too. I only took out 2 front fans .I only removed my 2cpu aircooler fans to clean
The remaining 10pcs casing fans, i cannot hahaha
Its nothing hard actuallyme too. I only took out 2 front fans .
The ID tower cooling fan is clipped onto the huge heatsink, i don't dare remove. haha
Ok to vacuum the motherboard itself?
i vaccum & wet cloth cleaning every 6monthsHow does everyone clean their fans ar?
Tedious process
that is good. i only opened up 2 weeks ago to do deep cleaning after 5 yearsi vaccum & wet cloth cleaning every 6months
u mean those black color magnetic mesh ar?I bought those superfine SS mesh to block all the air inlets. Doesn't clog easily and keeps the inside quite clean. Sure, got accumulation of very fine dust, but not enough to block the cooler vents. CPU and chassis temperature remains almost as low as when it was in the beginning
i worried i drop the whole pc down the stairs lolBuy an air duster. The topline jisulife would work.
Bring the casing to the stairwell and whack.
Lol. Be careful.i worried i drop the whole pc down the stairs lol
the power is comparable to the traditional can types?
Is still ok for me, but maybe because I bough fine metal mesh with very thin wires relative to the hole sizeu mean those black color magnetic mesh ar?
i also was thinking to buy but was wondering will add more stress on the fans causing lesser airflow ma?
because casing panel default already mesh liao then add 1 more layer of mesh over it, im worried will result in slower/smaller airflow?
