PC chassis cleaning
tigerwoods
okies done cleaning~
Just show off my Gundam casing again :ROFLMAO:
you dont find the bright lights distracting beside you?
peterchan75
A paint brush and a vacuum cleaner. The brush can reach the every nook and cranny of the PC case. After that use kitchen cleaning wipe from one dollar shop and remove those stubborn dust that still cling on.
KleoZy
Do we need a special anti-static brush for pc cleaning?
not really neccessary, Singapore hardly any static.. unless you stay in Aicon room with carpet floor..
place your hand or fingers by touching the PSU unit when it's on stanby (PC not on yet) apply anti static strap.
Then swtich off PSU, unplug AC, press PC Power button to discharged fully. you can proceed to dust off with brush.
paul02
Won't have this problem if you're like me who vacuum and dust every 4 months.
abstrax
How does everyone clean their fans ar?
I generally take a damp coth and use index finger slowly wiggle the blades one by one
Tedious process 😂
Just use a brush will do. Those paint brush. Use a mini vaccum cleaner to suck the dirt while brushing.
-Synchronicity-
For me, most important thing is firstly setup.
Make sure that your have a positive air pressure(more intake/higher rpm fans than exhaust) as this naturally pushes the air/dirt out from within the case. At the same time, make sure that there is a dust filter for all intake fans.
Next, I invest in those electronic compressed air duster. Essentially, it's those canned air but unlimited. I can always bring my PC to the staircase and blow away making sure to keep a finger on the fans to prevent it from spinning. Helps that the case is also very small(using jonsbo d32 pro). Can double up to use as a dryer for your car after washing, or your home fans, blast away the dust in it.
ragnarok95
Senior Moderator
Senior Moderator
As long as you hold a finger against the fan blades to prevent it from spinning, it's fine.
If really scared, yes can remove and blow the internals only.
Then you should have state it earlier because blowing on free spinning fans are a bad move.
