PC freeze without bsod
Informant
sup guys, i was wondering if secondary hard drive fails, will it affect my primary drive to hang the entire pc???
tigerwoods
can explain more details why if secondary hard drive fails will cause primary drive to hang? i google liao the answer very vague...
Windows will keep trying to access the failed drive and will cause whole system to stutter, lag and hang.
I having this problem now becos my sec drive is dying soon.
liewhl
Is this a assumption that your secondary hard drive had failed or did you confirmed that it is faulty?
Phen8210
Yes, especially if it has trouble initializing.. windows is not very smart.
oddbasket
A failing hard drive can cause booting into windows to become longer. If you start to experience long loading into windows, it can start with occasional to eventually every boot, u can try disconnect the sata cable to the hard drive to see if it boots into windows quickly or go without freezing.
86technie
Hang no, the most obvious will be slowdown.
PC hang can be due to faulty hardware or Windows issues especially wrong/corrupted drivers.
Which is why some here suggest do a format than install Windows to irony out the issue.
Phen8210
I think Infinite loading is no different from Hang, but it depends on what he means by Hang :ROFLMAO:
Informant
Remove secondary drive liao... after 2 week still hang... wa piang.. this mysterious issue has been going on for a year since 2023....
midlusionz
is your ram voltage correct? i had the exact same issue as u and its due to when i use xmp profile my ram becomes 1.2v
liewhl
if you dare, just dismember your whole pc, set it up on your table with minimiun part (cpu, ram and 1 stick of ram) and run for a few day nakely to see if the same problem exist or not. If yes then, then is one of the 3 part, if no, then is the rest of the part lo.
sometime, if your case bad grounding also can freeze ur pc
86technie
I think you bring to a shop let them check.
Can be either RAM or Windows issues.
googoogaga
First check whether you have any unstable software installed. Remove all uneccaasry software and drivers.
If fresh install of windows with no additional software is causing freezing issues then it is hardware problem. Main hardware culprits are graphics card, CPU, motherboard and ram in this order. Ensure none of these are over clocked.
If you are still facing issue then you will need to replace a new one.
I faces similar issue in my old PC. I bought a new PC cause no time to sit and debug.
Informant
I no time to individual diagnose the root cause. I just find every month freeze once or twice is annoying.
I send them for diagnostic liao.. if they find no issue how?? they say going to change the PSU and Mobo + clean windows installation (format the whole ssd).
Once fix plus replacement still got issue after 1 month means what??? I only on chrome and bluestack emulator on weekend nia. Mostly chrome on only.
any advice for them to change the most critical component first then see how? It’s unlikely they gona change the whole component.
liewhl
Actually any part of the pc component (ram, cpu, mb, psu, GPU) if faulty can freeze your pc randomly.
If can simply name a critical component then the shop technician should be technical enough to solve your issue liao.
Informant
ask y'all ah, if pc freeze, unplug gpu cable then plug into onboard graphic will automatically recover the display freeze to determine whether gpu likely the root cause?
liewhl
If you can recover like that, your PC most likely did not freeze. If really freeze, you cannot recover like that one.
Highly likely i think is either the GPU or the cable or your display.
