it happens usually during surfing chrome or trying to downloading a game from steam.
how do I start troubleshooting? should I reinstall Windows?
any advice is greatly appreciated!
Sent from my air hole using GAGT
brand new graphic card.. less than 6 months old. of course there is the possibility of defect goods. so I will check this aspect too. thanks!Could be the graphics card going up lorry.
Thanks! I will try re installing the windows tonight.Hanging symptoms could be a sign of one of your hardware showing symptoms of failure. Can try reinstall windows to ensure that its not a software fault. But if problem persist it could be one of your hardware failing. Try reseating rams, cleaning the dust, or removing parts of your hardware to isolate the problem and replace it with new parts as necessary.
didn't suspect Chrome to be the issue until you said it here! Will try to uninstall Chrome and try using other browsers to test the machineSame Ol' issue.. Highly suspect cause by chrome browser. Before anything else, uninstall chrome and try again. I can say 80% cause by it. Recent chrome has been giving issue since Windows 10 OS build 1703 ..
https://productforums.google.com/forum/#!topic/chrome/OmSEKxIb-PE;context-place=topicsearchin/chrome/authorid$3AAPn2wQefIPsMVfwj0xdf6EV5kmfCkomcMEHgnPuV7txAzwG5_R7zSXpUDC4mJkgtzYL6qhwNobtr%7Csort:date%7Cspell:false
After you confirm once it is chrome browser .. Either you download Win10 Media Creation Tool and create a latest 1809 ISO then clean install OS. (Dont bother update, it does not help.) Or you use other browser.
By any chance, nvidia geforce experience also having the same behaviour and either you uninstall it or use my method above.
wow.. good to know! thanks!updated to windows 10 OS 1809 giving me too many issue....cause stuttering and hang.......reinstall windows 10 OS stayed away from it and left it to windows 10 OS 1803 version everything turn to normal
uninstalled chrome, but pc still hang at the Settings pageSame Ol' issue.. Highly suspect cause by chrome browser. Before anything else, uninstall chrome and try again. I can say 80% cause by it. Recent chrome has been giving issue since Windows 10 OS build 1703 ..
omg.. it's not running on my installation DVD.. is my cdrom spoilt??
oh my.. the problem worsen!
I only have my win7 installation cd.. and unsure how to enter Boot Menu from boot up.
help please!
