Pc not able to power up
86technie
I had a similiar issue back a few months ago. Couldn't power up PSU, thus i went to get a new PSU and still couldn't power up. After some investigation, it seemed that the old PSU was fried and in the process, the mobo and the gpu was fried as well.
Good thing the mobo was under warranty and that was replaced. For the GPU, i'll probably have to wait given the current situation of the GPU market.
Dead items
- Cooler Master V700 Gold
- MSI GTX 1080 Gaming X
Current setup
- Corsair RM750
- MSI B550 Tomahawk
- AMD Ryzen 5600
- Asus GTX 1030
Cooler Master PSU does not have good review and when PSU blows
it will affect more than component.
Do check if your RAM have issue or not, RAM also can give issue like PC on than off.
Mana
No issues with Ram so far. All working fine.😀
mcviechua
Hi, would appreciate if any help is possible.
I was attempting to add a GPU (spare one) to my existing setup. When installed the GPU, everything looks okay, both my GPUs were lighted up when switched on. But no display :(
I remove the newly installed GPU, tried to switch on with old setup (nothing touched). No display :(
I remove my other GPU, connect hdmi through the motherboard. No display :(
I tried several ways including reinserting ram, reinserting CMOS battery, but to no avail..
anyone have any advice/idea on what’s happening??
Thanks 🙏🏻
Yongkit
Thanks 🙏🏻
may i know if you have also try using different hdmi cable? could it be the cable connected to the monitor is loosen? any second monitor for testing or connect to TV and try?
