PC Power switch extension
Vanyel
Anyone use before?
Any possible issues with using this?
Shutterbox
Which part of the casing can the cables route thru?
Last time still got a hole with rubber grommet at the back. Now it'll have?
Vanyel
was thinking go thru the pcie casing slot cover *drill a hole
naked123
it's fine
im using one
but with splitter and reset button
i never connect LEDs cos they are super bright. also taped the connector up to prevent short.
dc2cc828e863832bb9736f1b4eaa44db_tn
sg-11134201-7rbmr-lnvbo2uh2rpk18_tn
i swapped one of the pci covers to something below. still have to use pliers to make the vent bigger so cables can go thru
sg-11134201-7rd5d-lwplt9gxeb6ba7_tn
total around $10 on shopee
Vanyel
should be getting from taobao, cheaper
now is just wondering which one is better
KleoZy
Vanyel
hmm.. are you on wired or wifi, if wired, can just use Wake Up On Lan and use your smartphone to turn on your PC.
I kinda feel that 1 button placed on the tabletop to turn on and off is faster and more convenient
My 2 boys pc is on the floor and deep in under the table
Also the PC isnt turned off completely if use the wake on lan
Vanyel
Shopee cheaper
The power/reset combo is around $4.5 on shopee
Same exact model?
Got link ma?
Generally made in china stuffs on shopee can all be found for cheaper over taobao because they are basically the same item
Vanyel
alamakazim
Don't even need to drill hole la... Sure can squeeze through some hole or sandwich it... Thin wires...
Vanyel
or even use
1) PC remote started.. https://www.aliexpress.com/item/1005007391529628.html
2) Mobile App Wireless PC remote start .. https://www.aliexpress.com/item/1005004685040707.html
3) USB wireless PC remote start .. https://amzn.asia/d/eLos0hj
I find this neater (no wires extending out) plus you will be able to retain case button to start your pc.
no space to add card for 1 of the PC, blocked by GPU~
Psycovirus
Got this Wireless Power button with the white box. About $15 last time. Link to product.
There are a few versions, some uses USB Power. This version I have does not. There's battery inside both the whitebox that is easily hidden behind the back panel and the power button. However, after using for 2 years, battery hasn't ran out yet. The white box also allows connection of PC case's power button so you can use either remote button or case button. Long press works too to force shutdown the PC.
If you're looking for small sleek version, this ain't it. this button is massive.
Koenig168
I thought of getting this some time back. Love the Evangelion theme.
Psycovirus
I haven't opened before actually. I got curious and checked. It's probably a circuit board from some remote... with wires soldered onto the button on the board and connected to the large nuclear button. the 12V 23A battery was just tapped onto it. such a ghetto way of doing things. Luckily, the 23A batteries are pretty cheap to replace.
This one machiam nuclear button 🤣
KleoZy
This is more practical, no wires.. just imagine you move your PC case and forget about the wires.. a simple tug, accident will happened. Else this is wireless.. GOOD. I like it. thanks for sharing @Psycovirus 👍👍👍
