Which mobile phone did you buy?definitely going Mobile over camera. in fact bought expensive mobile just for photography but cheap mobile for regular use
few years low light photography on mobile still pretty weak compared to camera. but it seems to have catchup.
currently still using huawei p20 proWhich mobile phone did you buy?
mobile photography quality good enough for IG & socials but not enough for large prints. but at consumer level, no one bother about large prints so non issue.
but for those who wish to pickup the fundamentals & perhaps consider going pro later, still essential to begin with at least digital camera.
no matter how there are limitations due to sensor size & lens. AI depends on pattern match, machine learning, so might be challenging for complex imagesA.I. processing can do large print
imo if want to learn the craft of photography still better to start with cameras.mobile camera phone in manual mode will do the trick too
As usual, many white elephant around...
not expert. i think megapixels are used differently in mobile. mobile cam uses pixel binning which creates "superpixel" from adjacent pixels (e.g 4 to 1). while 48Mp are used to create 12Mp image, this technique improves low light performance & quality on mobile camWell I never pixel creep all these years and though it is relevant in the past, now it seem that megapixel for handphone is not so important as I never ever deep crop.
this video below gives quite some ok understanding on it and it recommended 20-24 megapixel.
There’s some gaps between 12mp and 48 mp for some phones. What do folks here feel about their 12mp old handphone sensors? Good enough? Asking cos perhaps due time to upgrade my phone
Sounds chim. Do u think 48mp is worth it or overkill? File size gonna be hugenot expert. i think megapixels are used differently in mobile. mobile cam uses pixel binning which creates "superpixel" from adjacent pixels (e.g 4 to 1). while 48Mp are used to create 12Mp image, this technique improves low light performance & quality on mobile cam
no on mobile, 4p to 1p, pixel binning will create larger pixel & hence better light sensitivity. so it will create 12mp from 48mp.Sounds chim. Do u think 48mp is worth it or overkill? File size gonna be huge
At my current stage and family/work/life balance, I will have little time for any post processing of raw fileSome might call it marketing BS.
They could have tried to make a 12MP sensor better instead of stepping up on pixels and bin 4 pixels into 1 . But the way sensors are heading moving forward, it seems the "more" pixels the "more" desirable marketing wise.
I have no comparison as to whether a binned 12mp is better or a normal way of 12mp is better.
One can also argue that they want a 48mp raw file to work on, but if it demands that level of details might as well use a DSLR/mirrorless.
I guess I'm still one of the rare ones who still shoot with my mirrorless camera over phone daily. Transfer raw to phone via WiFi/USB cable and processed raw file using Adobe Lightroom mobile only.
Yes, it's foc to download and use with some limitations. Without subscription you only can edit JPG and 2 raw files (DNG & RW2 for Lumix).Adobe Lightroom for mobile is foc ?
I am using an old Sony mirrorless, the only way I can get raw into Android phone is via a USB C card reader..
For other brands can try using raw2dng to convert. But it might not work for some models.
