Please comment on rig build
kenny_2828
Antec 650W to power 2x GTX 760, overclocked CPU and a H60.
It will be just nice with very very little wattage overhead, or will not run at all. CPU is running at how many volts?
CPU Vcore 0.880 (non-oc) idle
royfrosty
Yep I have 2 fans at the back for radiator it came with 2xCorsair fans and long screws... Since no top exhaust on the case, I configured both to blow the hot air out in the same direction...
I wanted green actually but its popular so out of stock... :( Oh well some bling bling wont hurt :p It kinda looks nice actually with 1 green 1 blue...
Thanks Roy for your help, it really helped me a lot to make my decision... You have a good weekend!
No problem. Nah not enjoying lol, working right now.
Op_Valkyrie
what gfx u r using? the cooler and partial back plates looks nice...
:o
kenny_2828
:o
Cheapest 760 around - Palit Jetstream @ 369 but I managed to bargain down a bit when I bundled everything together...
It looks heavy but compared to my 580 gtx Twin Frozr II it is much lighter...
The non-jetstream version is around $20 cheaper? But since running sli, might as well get a better cooler and the clock speed is slight higher than non-jetstream...
On SLI load first card is around 70-75 and second card hovers around 45-55 ish... Idle is 52 and 46 respectively...
royfrosty
:o
That is the Palit gtx760 jetstream. That black backplate is way cooler than what you think. It is part of the heatsink also. Helps in dissipating heat also.
I can say it is a very nice card to use. But their Thundermaster software is crap. Quite buggy. So decided to use Asus tweak instead. Easier to use.
royfrosty
Poisonous sia, now make me gian to get my final jigsaw puzzle.
kenny_2828
Your Palit 760 needs a companion, otherwise it will feel lonely... :D
760 SLI scales very well in supported games :) On par and often, better than Titan for its price $369x2 vs $1500 for titan...
Just do it! No regrets! haha
royfrosty
Si bei Chek Ark~
BTW the SLI bridge comes with it? Or you purchase it seperately?
