plz help mi regrding note 2 export set
javid1987
Im panning buy export set since cheaper.
I know no warannty.
But other than that wats e diff ?
Is export set means cheap quality or wad?
Will it spoil easily under normal use?
Fyi, I will use note 2 for call sms watsapp surf net watch movie listen songs n play highnendgames
Plz advise mi
satch
Export sets are purchased by shops from suppliers who don't get their goods from Samsung Singapore. Goods are still manufactured by Samsung and still subject to their quality control etc so I don't think u can say quality will suffer.
monkey18
I know no warannty.
Plz advise mi
so far so good i'm using now....everything quite good and smooth except just now experience a lost of sim card and need to take out and re insert.
javid1987
Export set no LTE aka 4G whereas local sets have..
I dont even have a data plan. haha. always wifi.
thnx 4 e info
hmm. thnx.
thanks everybody 4 ur quick resposne. i think i will go ahead n buy e export set.
LesterQ
If buying a 800 dollar phone why not pay That hundred more for a peace of mind?
If you like to buy cases. Just don't buy any case instead and pay for the warranty. I think it is worth it having the warranty if anything goes wrong.
But if you garang and go ahead buy export set, wish you luck! Haha
IncTEh
TS, i suggest u get a local set. higher resell value also. if u get an export set for let say $150 lesser, and 2 years down the road, u wanna sell, im sure your local set will worth more than $150 more than the export set, given that local set has 4G, which most people would want at that time.
monkey18
for resale value...i think is almost the same lah, u buy ex..u sell ex, u get cheap u sell cheap.
satch
It's harder to sell export sets... and shops are reluctant to take in export sets also.
monkey18
most of all...enjoy your set first, why worry abt 1-2 years problem unless he can wait...if not the price between export and local set. diff by 150-180. but of cos if price doesnt really matter den surely will go for local set.
satch
If use more than a year then no diff in resale price cos no warranty for either case. For me I change quite often so getting a local set makes more sense cos easier to sell off.
javid1987
thnx 4 ur replies. i totally 4got abt resale. i think its almost $1000 for note 2 local set. but export set i can get for 760. so huge difference.
wont singtel or starhub take ? maybe slihglty lesser ? or they wont take ?
monkey18
i doubt telco will take in export set...
satch
telco probably take but telco trade in price very pathetic and u need to buy a phone with contract from them. ..they dont just buy ur phone.
Most dealers will mark down some more for export sets, if they do take in.
satch
Telco don't check. Last time I traded in a nearly junked e52 nokia. They looked at the phone. Tried to switch on. Press a few buttons. Then put in a plastic bag and threw it one side. Lol.
javid1987
ya. true. telco trade price is pathetic. but after u all said i find uneasy buying export set. i think i juz buy an s3 :)
V
victorlht88
Guest
Telco max trade in price for phones is $400 even if you give them a phone made of gold.
javid1987
may i know where u goonna buy export set?n wat the price?..thanks
Im not goin buy. Deicided not to buy. So I will juz kepe e s3 telco set when it arrives this tuesday. mine is a non data plan. therefore i cant prchase note 2 lte. thats y i online recon to s3. then i though of selling the s3 for $740 when i get this tuesday n buy note 2 export set @ burlignton square(fb page is adix82). but many r advising mi not 2 buy die to resale value. so i think i juz stick 2 s3.
