Poco F4
elvintay07
Suspended
Received my unit but it doesn’t power on. Plug in power supply also no response. Anyone know why like this?
ekardo
ya..I encountered the same thing also, just keep it plug on for sometimes.. use the fast charger if your existing one didnt help..
TimberOak
Poco F4 has free 6 months screen replacement for sets purchased until 27 June 2023. Not bad for a budget phone.
Consumers who purchase a POCO F4 between the 27 June 2022~27 June 2023, at any official sales channel (online or offline) of Xiaomi in the Territory of Singapore (“Territory”) and activate the Product within the Territory, will be eligible to a one-time (1) free repair service at the local Xiaomi´s Service Center during the first six (6) months after the purchase, if the screen of the above mentioned Products is damaged or faulty by a non-intentional action by Consumer (i.e. like non-intentional falling of the Product).
elvintay07
Suspended
Means quality cui?
really_noob
Means if screen no issue cannot claim warranty? After 6 months of purchase then screen got problem then cannot claim. I don't get the logic, if it is manufacturing defect, their fix feels so half hearted.
acidcrash
F4 6/128 still worth to get these days? Lazada got flash $283. Currently using Poco x3 pro.
Brovale
F4 is still a great buy. If budget allow, go for F5 could be better, which is a year younger with a newer and better performance chipset - SD 7 Gen 2. And as usual, Xiaomi offer to cover 2 updates, F4 already updated once from Android 12 to 13.
caterham7
yes, super value-for-money
while other people are paying $300 to get a low-end or mid-range CPU, f4 comes with sd870
do note some features are missing compared to your x3 pro,
e.g. no 3.5mm headphone jack. can consider f5 if u want headphone jack. f5 pro also no headphone jack
e.g. no microSD support
Johnringo
Default cam: try using Document mode to take, works well for me.
general cam improvements: join @PocoF4Discussion on telegram and install lmc8.4 with phoenix or kcpd XML. ( Use the rose bot and type #gcam)
hi, just want to check, i install the lmc8.4 which is an apk file so that is a camera app? How do I install the XML file after that?
