Poco F4
tian_yibang
slowness...the phone getting slow..
super laggy even even just by unlocking...somehow think the ram management is crap...cos after a while the phone is working normally..
This is before or after update to HyperOS ?
tian_yibang
After hyperOS. Been like that since upgrade. Sibei sian. Like a low class phone cos have to wait 20-30s for phone to stabilize after unlock.
Chiu gotch do factory reset after upgrade ?
Moi read somewhere that says its recommended chiu to do a factory reset (format/reinstall) after every "major" UI or OS upgrade so that it will start on a "cleaned" state , unless its the upgrade gotch issue
Thats why many ppl hesistant to "upgrade" if they dun see the need , bcos scared kanna problem or dun want go thru leceh to re-setup the fone from all over again
As saying goes - Dun fix it if aint broken
And also dun forget ifong that famous saga where they slow down chiur fone after update/upgrade
Hypernova
so far rumours pointing to
F7 - Redmi Turbo 4 Pro
F7 Pro - Redmi K80
F7 Ultra - Redmi K80 Pro
Read HWZ Forum Rules on Poco X7 Pro
Other than F4 which had a GT version(ultra) the subsequent F series don't have. I doubt F7 will come out with ultra though. K80 is most likely the pro version already.
Currently K80 is using SD 8gen 3, the second best chip in SD line up. 4 months down the road it will still be in top 3 I think. SD 9 no rumors yet, so maybe after Sd8 elite might have elite2 at most.
ekardo
still looking for sub $300 replacement for my poco F4...any recommendation?
Hypernova
you want something better but sub $300...wait a couple of months until release of F7...F6 might go below $300...
