No choice live with it, same for me.Don’t think will upgrade. Scare will slow down the phone.
Chiu just tahan the constant incoming notification?No choice live with it, same for me.![]()
Yes, better than upgrading and risk screwing up the phone.Chiu just tahan the constant incoming notification?
Ic if HyperOS is problematic then wouldn't the new Xiaomi models that already come with HyperOS have problems also? Or do the problems only arise for those who update their Xiaomi-s from MIUI?Yes, better than upgrading and risk screwing up the phone.
Not gonna fix something that is not broken.
I discovered some functions are lost, like scheduled power saving mode, which is helpful. I had provided feedback in their feedback channel/app IIRC and hopefully future version brings back such functions.Ic if HyperOS is problematic then wouldn't the new Xiaomi models that already come with HyperOS have problems also? Or do the problems only arise for those who update their Xiaomi-s from MIUI?
The options are just at different place. For the scheduled battery saver mode, it is atI discovered some functions are lost, like scheduled power saving mode, which is helpful. I had provided feedback in their feedback channel/app IIRC and hopefully future version brings back such functions.
Feels like a regression if such essential functions (to me) is lost, and also who knows how compatible it is to upgrade for the older models to HyperOS thus, the reluctance.
I'm one that is always happy to upgrade to the latest version if possible since it usually means better security and support for my devices, but unfortunately not this time for HyperOS.
Still adopting the wait and see attitude, probably down the line when forced to upgrade I guess.
Oh wow, its actually there.The options are just at different place. For the scheduled battery saver mode, it is at
1) Battery > Current Mode > -Change it to battery saver first-
2) The battery saver settings menu will appear. You can find the scheduling inside.
3) Change back the current mode to your original, eg balanced.
Their UX engineer never do a proper job.Oh wow, its actually there.
Don't get why its hidden in sub-menus instead...
Appreciate the sharing @swathe !
Yes, still need a lot more time for polishing to make it more friendly and effiicent.Their UX engineer never do a proper job.
Just treat like using a different brand of phone and the menu options are different.
what app to debloat?I have Poco F4, am on Hyperos, debloated some apps away. There is minor app crashes, but otherwise I think not much speed difference from the previous OS version.
my f4 very laggy since upgraded to hyperOS....
hmm..not so direct with this method...but thanks!https://github.com/0x192/universal-android-debloater
Choose Xiaomi, try to do only the Recommended ones unless you are sure what else to remove.
me.Anyone updated to 1.0.8?
Yet to receive.Anyone updated to 1.0.8?
