Poco F4
JuXn5566
5 % included R&D, marketing, sale.. Etc.. U all think only the price of the raw material?
Right but if Poco F3 can sell so low at less than $300. What major R&D involved needed to upgrade from F3 to F4 ? Cost so much to change the casing/shell?
FinalTidus
Actually I feel Poco/Xiaomi this time have dropped the ball really hard. Never have I seen a company name a sequel to a phone that is using the exact same SOC and upgraded the number.
There are probably technical reasons why they stuck to the same SOC (888, 8 Gen 1 have heating issues) and I respect that. But just upgrading the shell/casing and minor tweaks to the camera doesn't justify a whole number upgrade. Furthermore the price is jacked up.
Not cool.
Instead the F4 GT is looking to be a more appealing phone although honestly the price is still not low at all for a mid-high ranger. So its not a must buy category yet. At least for me.
tian_yibang
For those using this phone
what are the pros and cons ?
ie. the OIS seems to only work well on 1080P video instead of both with 4K
and the 4K recording is limited to 8 mins non-continual , meaning it will auto-stop recording at end of 8 mins mark and will need press start again over and over
is this true ?
shawniiex
Hi all, looking to upgrade my dad phone from S10 Lite to this. Or anyone has other recommendations for this $500 price range.
Read online sd870 still a safer option compared to 888 and 8gen1
progene
Yes. SD870 still a better option. Wait for 2.2 promo ba.
8-lane
I may be wrong but isn't Poco F series phones gaming phones? Will ur dad be using it for gaming?
shawniiex
Haha. Aren't all gaming phones good enough phones for someone like my dad then? Or do you have any other suggestion for the price point?
caterham7
what are your dad's usage requirements?
e.g.
if want to have good camera output, for $500, i would recommend google pixel 6a
if bang-for-buck, can consider poco x4 gt, cheaper than f4, but cpu is newer and maybe even performs better in some scenarios
https://nanoreview.net/en/soc-compare/qualcomm-snapdragon-870-vs-mediatek-dimensity-8100
if have specific requirements, e.g. want micro-sd slot, want 3.5mm headphone jack, can use gsmarena phone finder to narrow down your choices
https://www.gsmarena.com/search.php3?
shawniiex
e.g.
Hmm no specific requirements.
Just use to drive grab, come home watch Netflix.
So I wouldn't want to get him the pixel given the subpar tensor chip.
Just curious how stable Poco phones are compared to like Xiaomi in terms of software.
progene
Been using poco since 2010.
My daughter using Poco X3 NFC since 2020. And me using Poco F3 since last Apr.... so far the software is stable..only thing is that u need to disable all the ads after taking out from the box...
shawniiex
Thanks bro. Appreciate the assurance
aljj1996
Previously i was using x3 pro, mi 11 and redmi note 9 pro and i feel there is minimal difference from xiaomi since they are coming from the same miui. So far so good for me for general use
windwaver
e.g.
I also have a budget of $500, so Poco X4 GT is better than F4? Prefer 256GB internal memory.
Will Dimensity 8100 over heat?
Prefer feedback from real life usage, reviews can be skewed at times.
Happy CNY!
caterham7
if use for drive grab, i presume screen will be on for long periods of time?
if so, maybe avoid amoled/oled screens, and look for models with lcd screen
to avoid screen burn-in
caterham7
Happy CNY!
suggest to use https://www.gsmarena.com/compare.php3 to compare between 2 or 3 models, in this case, so that u can see the difference between f4 and x4 gt, see which one more suitable for your own usage scenario
8-lane
Hmm come to think of it... gaming phones usually have special cooling systems to prevent the phones from overheating... wouldn't that be good for ur dad since he will be almost using the phone all the time when he does grab?
shawniiex
That's why all the same lo in the end 😂
Oof LCD vs LED though, he's quite used to the quality of LED screens already.
But thanks for highlighting.
Does Xiaomi shops have Poco on display? Or where can I view?
