POCO X3
limjialok
Found a few carousel sellers claiming to be selling local poco x3 but without the ein stickers. Is there any way to check if it's indeed local set instead of export?
subisisniki
You guysanaged to get the notification light to work? So far it's only working while charging. I've enabled the light in additional settings and also enabled it individually in the app. But still no light
twosix
yes it is working. i use it for sms, whatsapp, telegram, etc...
Reavl
If u don't mind, X3 is thicker & heavier than redmi note 9 pro.
And reviews also seems note is much more stable even for export set.
thank you for your reply, so the Xiaomi Redmi Note 9 Pro also work with tpg? is export set mean china rom?
limjialok
and anyone faces UI lag after a few days after rebooting? seems to be a common problem based on online compains
highdiver_2000
Yes it lights up whatsapp and sms. I didn't do anything.
highdiver_2000
Just clear all your recent apps. I do this out of habit. A few times I forgot and the launcher reloaded.
Yesterday, I started to download the photos and whatsapp started crashing.
All indicative of poor memory management.
allanzzz
Anyone have issues with blue tooth?
I leave mine on all the way, but sometimes blue tooth earbuds cannot connect to it.
Tried to off and on blue tooth on the phone but unable to do so. Had to restart the phone to resolve it.
my phone is pretty stock except for some settings to force the panel at. 120hz.
justln
No issue with bluetooth, uninstall Trace together app if installed or change bluetooth earphone try again.
desmond007
Don't fall for it...the sticker is there for a purpose.
Moreover the price diff only $30-40, take local set for peace of mind. Go race course rd...their price is the lowest.
desmond007
Tpg I've no idea.
Depends...if u buy online from overseas seller, some are China rom.
Local retailer mostly int rom.
Diff is mainly the local warranty.
U can check before buying.
konoha
if u can play brawl stars smoothly, i think most of the games are still ok wat..
kazuki666
https://qoo.tn/BKqUVX/Q130385668
Anyone bought their set here? Seller claims have local warranty wor. I thinking to get a 128gb set for daily personal use, then current F1 64gb switch for office use only...
Sent from Xiaomi POCOPHONE F1 using GAGT
limjialok
Race course road is OnePhone singapore? I saw a local set poco x3 128gb at $340
