POCO X3
NewUser001
My Poco F2 Pro had exact same problem, brought to Mister Mobile to get CPU temporarily fixed (presumably CPU reballing from what I see on YouTube)
The repair was $68, they advised saying it is not a permanent solution, I told them it's fine, I just need to get my data out.
They didn't tell you what they did? How long did they take?
EveMuffins
recently my batt draining very fast due to 'cell standby - battery used by radio'. i do not use any radio app at all. anyone having same issue?
this phone don't have sim card, using WiFi only
luei74
Sorry to bump this up๐Ÿ™๐Ÿ™
Just changed my Poco X3 GT battery in CT for $45. Xiaomi CSC no longer support for this model anymore, got it Jan 2022
Hopefully 3 more years to go with this little gem๐Ÿ™๐Ÿ™
luei74
Bingo.... ๐Ÿ™ ๐Ÿ™ :LOL: :LOL:
My Max 3 running for 3.2 years (still going strong, just that banking app doesn't works due to an older android ver), would like to see if the x3 GT can go for another 2 more years :LOL: :LOL:
caterham7
can look into which budget model ? Poco or xiaomi/redmi/note? Budget not more than 350..this for work phone
Many budget models from Xiaomi from $100.
Maybe provide your feature requirements to help yourself narrow down the choices
E.g. 3.5mm headphone jack, esim, microsd, ir blaster, nfc, etc.
