POCO X3
-ASL97
why
is the x3 pro so cheap? the new f4 with similar memory size is around $630, more than double
Read HWZ Forum Rules!
it cheap because it uses the binned older chip from 2019, uses LCD, slower touch sampling, not as bright, not the latest gorilla glass, slower older LPDDR4X, slower charging module, no wifi 6, no 5g, no physical trigger, lesser ram, lower resolution camera, dual speaker only and it's to get the POCO brand name out
and probably a few more stuff I missed out
luei74
why
F4 under F series slightly higher grade as compared to X3 Pro....if u would like to get the current F3 8/256 under flash sale can further down to £373 before voucher kicking in...
F4 on next year should be under sub £3xx too...
Hypernova
Just got notification for X3 NFC to upgrade firmware to 12.5.7.0. Upgrading as I speak.
Just a security update.
icestorm
Is X3 NFC able to connect usb c to hdmi output? I tried to connect with usb c to hdmi cable. However I do not see anything on the TV / monitor.
eriol125
Not all USB-C ports support video output; a device is required to specifically provide support for USB-C Alternate Mode, which dedicates some of the physical wires in a USB-C 3.1 cable for direct device-to-host transmission of alternate data protocols.
See here for more info
kazuki666
I just found out the screen protector on my X3 Pro just cracked, weird because i dont recall bumping it on anything.
Does anyone have good recommendation for X3 Pro? I realise the screen protector I tried either the edges don't stick well (with white bubble around the edges) or its smaller than the screen itself.
Also just curious. A good screen protector should or should not cover the selfie camera?
ridiculous?
Came with screen protector. Most likely for the edges of newly applied sp?
:o
