POCO X3
shortslippers
Guess it will be some time to before they come out with magnet ring case with rectangular cut out for back camera.. I buy magnet ring stick on freebie case tong first.
bellevue18
Question - does anyone know if unlocking the bootloader of the Poco X3 will void the local warranty?
rathalos
Hi, we would like to inform you that by just unlocking the bootloader your device warranty will not be void. However, if the device crashes/bricks due to Custom ROM the device will be serviced out of Warranty. We would strongly recommend you to continue use your device with MIUI.
Answer is, no..
petricnah
Hi, anyone know how to activate the wifi direct?
The function is gery out.
Thks.
Posted from PCWX using No nnpnt
micgoh
I use the poco awhile but decided to go back to my mate 20x.
So will be selling it away. I think mate 20x still shiock
EveMuffins
https://shopee.sg/For-Xiaomi-Redmi-...-Case-with-Slide-Cover-i.279383807.3164162083
e6ba14955e2ccbe61884742a8aa386ad
Heard people talking about this case with camera cover? But dunno if it's really X3 design or just K30.
Edit: Asked seller, reply was "hi friend,we contact the manufacturer tomorrow,can we tomorrow will tell your answer?" :s13:
Means not only the screen protector, even for casing, k30 and X3 same?
justln
Thks.
Maybe try Nearby Share, it's Android build in function to transfer files, like Apple Share.
Maybe no mockup for POCO X3 and they need to order/manufacture. :s13:
EveMuffins
I see..then I better don't order any flip case first..will bring my Note 4 out for the time being. X3 use at home first.
