Pocophone X3 Pro
clock_ED
Should be good enough, has seen one of the reviewer playing with it and it seems like he is getting a solid hit due to the fast response 240hz touch sampling.
Thanks but I’d assume he is using the 6 (or 8gb) version?
Tempting as hell $269 VS $339 argh
Btw, Bronze 6/128gb all along blanked out or OOS? :(
iDexPro
Screen wise Note 10p is the best? Intend to use it for media consumption and browsing, no gaming
If you don't really need the performance, then go for N10P as it's the most practical. X3 Pro is heavy due to the huge battery, and F3 you lose the headphone jack and SD slot.
Ye_Rongtian
Well I don't see why they can't make it below 200g when M3 and Redmi 9T is 198g, with bigger 6000mah battery.
Dorkable
Samsung Galaxy M31 also has 6000 mAh batt and weighs below 200g :p I wonder why, too XD I really think they could do it, but chose not to.
lbcben
just purchase at 2.10pm, $30 off still can use.
stated Global version, so google will come with it, corect?
Yes, even if future I reset to factory, google by default will still be inside?? or no more?
