- Jul 14, 2005
What phone bro? X3 pro?i just checked mine 12.0.2 still have the option to disable MIUI optimization in developer settings.
YupWhat phone bro? X3 pro?
Zzzzz.... kao.... what is wrong sia....
Wahhhh ????!!! Hmm so because I updated to 12.0.4 that option is gone? Lol!i just checked mine 12.0.2 still have the option to disable MIUI optimization in developer settings.
i havent set up mine or update it. just switched it on to have a look. so... could be 12.0.2 is the last version?Wahhhh ????!!! Hmm so because I updated to 12.0.4 that option is gone? Lol!
Sighhhh ok bro, maybe bah...i havent set up mine or update it. just switched it on to have a look. so... could be 12.0.2 is the last version?
I go explore see how to downgrade....Sighhhh ok bro, maybe bah...
Ours dont have bro. We checked through multiple times leI don't have x3 pro but I am using x3 NFC. Miui 12.0.4. I have the option to turn off miui optimization... It's right at the bottom of developer options, all the way down.
should be a android 10 vs android 11 thing. i kept the X3 Pro liao so cannot confirm. 12.0.4 shows android 10 or 11?So weird, different phone different setting.. hope my F3 will have..
Highly possible... cos miui should be just the xiaomi skinshould be a android 10 vs android 11 thing. i kept the X3 Pro liao so cannot confirm. 12.0.4 shows android 10 or 11?
but is it recommended to turn off or on? I read turn off alot things not working properly. And also, for china rom turn off due to the aggressive background task killingFyi, my other xiaomi phone on global rom 12.0.5 can see option to turn on mi optimization. But i don't dare to turn it on though. Later cannot find the option to turn it off again
i turned it off for my previous xiaomi phone (redmi note 3) so the apps can stay alive in the background but during that time it's only 3GB, now it's 8GB so don't think it's really neededbut is it recommended to turn off or on? I read turn off alot things not working properly. And also, for china rom turn off due to the aggressive background task killing
Haha just did a factory reset, no go. Ahhh ....Ours dont have bro. We checked through multiple times le
Lol thing is, I updated it out of the box (without knowing it's on or off), go into Dev Mode, and it isn't even there lolFrom what i read in the mi forum just now.
If you already turn it off before you update to 12.0.4, then you can see the option to turn it back on.
After you update to 12.0.4, no option to turn off miui already. Have to root and use something like shell command.
So better don't update first before you disable the miui optimization.
I still waiting for F3, so not sure if it is working.
