Pocophone X3 Pro
ZhuTou!
Eh why wanna go through downgrade process just for yt vanced lol
Just use the original yt la :s13:
bbcccc
From what i read in the mi forum just now.
If you already turn it off before you update to 12.0.4, then you can see the option to turn it back on.
After you update to 12.0.4, no option to turn off miui already. Have to root and use something like shell command.
So better don't update first before you disable the miui optimization.
I still waiting for F3, so not sure if it is working.
not true, I turn it off b4 updating n the option is still not there after update. is fine for me since I using vidmate instead of ytv
Nakedtoes
Heng I got keep microg and vanced youtube older version.. Dun need to disable miui opt..
左青龙右白虎
My YouTube vanced also unable to work.
As for now, I just use expressvpn for free trial 7 days. Go to India or Argentina servers. Subscribe YouTube Premium only less than $2 per month, less than a drink, save u the headache. Only need to do once and recurred monthly charges automatically. Just terminate the VPN. Just use Google Maps find a place like shopping mall, get the address and fill up when prompt to fill a local address and postal code.
lbcben
may i know if I factory default X3 Pro, will google "come back" by default still inside? or reset already will become "china rom without google"?
KeYoKe
Wont. Default is global rom. Factory reset also is still global rom
Unless originally is china rom, u install playstore yourself, then factory reset will remove it
