Pocophone X3 Pro
verydisappointed
Yeah, same feedback I got while in bright sunlight. The stock pasted screen protector isn't helping either; very easy to retain oil smudges on surface which cloud the screen fairly quickly
Hihi. The phone already have screen protector pasted on already ?
If I purchased a screen protector, do I need to remove the stock sp ?
ZhuTou!
Every phone stock sp is just a thin sheet sp prevent scratches only, wont prevent impact
Its like the old days of sp before TG came out
Need to remove stock if applying another one
Dorkable
The stock SP is not of good quality on my x3 nfc. Guess they use the same one here.
I recall my X3 NFC's stock sp was so lousy, I had to remove it entirely. This time round, I reckon the sp quality improved some on the X3 Pro, at least I ain't going crazy over it yet, haa.
garychengjw
XM's stock SP quality felt the same across all board. in my experience with x3 nfc and x3pro.
Fizzical
Its not an issue rather, its programmed into the phone... there is however a workard.
It makes everything 120hz, but idk how it will affect battery consumption, im running 60hz rn, can somebody tell me how is the drainage difference between 60 and 120hz is like?
If this is not allowed, mod please delete this post
Btw thanks. Will definitely drain but not that bad. Maybe 10% hit in battery drain.
frizee
Hi for the POCO X3 Pro, if I'm looking to get the camera protector, is it also the same as X3 NFC?
Second thing is, how can I ensure my microSD is encrypted? Can't seem to locate that option though.
Godeau
Same as x3 nfc. As for micro SD card encryption, don't have a clue...
Godeau
Anyone pasted rear screen protector here? Probably not gonna bother with it, with plastic back and the curved edges, means if you ever decide to place your phone into a snug fit case and then take it out again for whatever reason, the rear sp gonna get ripped off on the edges too
tszkitc
01-04-2021 15:55
[SG_DC] Your parcel has been received by sorting center:(:(:(
ZhuTou!
Cam no need protect one
The glass is diff from usual
I have never seen my lens scratch or dmg for all my phones before
Taobao/aliexpress some seller sell those combo TG
Screen+cam in 1 package
frizee
Just wanna be safe and thus, adding a protector for it.
Anyway... No prob, managed to get from Ali already! Thanks anw :)
Angtehkor
Someone suggest if you want your phone to charge slightly faster, just off your phone when you charge.
