Pocophone X3 Pro
Skyy
Apkmirror also got older versions of YouTube Vanced
Angtehkor
Watch video on YouTube no need full blast the volume, put 3/4 or 2/3 volume is really loud enough for me. Really very good.
holyAngelX
30-03-2021 03:32 Your parcel is shipped from our sorting center in Hong Kong SAR, China
Cross finger that the plane lands soon so can enjoy setting it up over good Friday
Angtehkor
Hopefully you can get your phone by tomorrow
Fizzical
Hi guys. Anyone noticed that chrome browsing is running at 60hz instead of 120hz? Other places no issue..running at 120hz...
Got any workaround?
Missiledude777
Got any workaround?
Its not an issue rather, its programmed into the phone... there is however a workard.
It makes everything 120hz, but idk how it will affect battery consumption, im running 60hz rn, can somebody tell me how is the drainage difference between 60 and 120hz is like?
If this is not allowed, mod please delete this post
badstudent
Don't think it will be an issue with the massive battery in the phone, should easily breeze thru a day even with heavy usage at 120hz I guess.
No point buying a phone capable of 120hz and make it run at 60hz. Just like buying a ferrari and drive at 20kmh.
Fizzical
Anyway solved the Chrome issue. Now the phone is good. So far no gripes about it other than cannot remove app drawer. just need to get use to it.
Dorkable
I am one of them who runs it at 60Hz, hee.
badstudent
Your choice though but the battery is so massive, should easily breeze thru a day with minimum 6hours screen on time even with 120hz I guess?
Will be good if you can stress test that and share with fellow users here!
Dorkable
So far, with 60Hz and on constant WiFi connection, my Screen-On-Time was already 9 hours when it hit 20% battery last night. My usage was mostly surfing websites, and via Shopee and Lazada apps. Others included an hour of gaming on Pokemon Masters Ex and watching some Youtube vids.
By the way, I am using Light mode (coz I gathered that it doesn't make a difference since X3 Pro is using an IPS screen) and switched off wake-up screen by Notifications. Also have 11 main apps set on Autostart, with no battery saver restriction.
Missiledude777
Dark mode user, running at 60 FPS, yesterday I started at 100%, played CoD M for 2hrs, the battery lasted till night at 60%, surfed YT for 4 maybe 5 hrs, today, and battery hit 30% at 2pm today... now testing with 120 FPS...
Ye_Rongtian
Err... Dark mode doesn't save any battery on LCD.
Godeau
The X3 Pro screen is really rather dim. Wish I could have the same bright and vibrant IPS display on my budget tablet Alldocube iPlay 30 Pro, haa.
Yeah, same feedback I got while in bright sunlight. The stock pasted screen protector isn't helping either; very easy to retain oil smudges on surface which cloud the screen fairly quickly
bbcccc
the brightness is slightly lower than my old poco x3 nfc for sure on same %
