Possible that old psu will cause memory bsod issues?
kreja
I'm keeping my old rig alive for my every other non-gaming pc needs. I swapped in an older 500w psu and noticed that I'm getting alot of bsod which I suspect is ram related. Question is can old and lower wattage psu cause bsod? weird...:s11::s11::s11:
kreja
Microsoft (R) Windows Debugger Version 6.3.9600.17237 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [e:\110914-6926-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
************* Symbol Path validation summary **************
Response Time (ms) Location
Deferred SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7601.18526.amd64fre.win7sp1_gdr.140706-1506
Machine Name:
Kernel base = 0xfffff800`0301b000 PsLoadedModuleList = 0xfffff800`0325e890
Debug session time: Sun Nov 9 21:54:49.555 2014 (UTC + 8:00)
System Uptime: 0 days 1:07:00.381
Loading Kernel Symbols
Press ctrl-c (cdb, kd, ntsd) or ctrl-break (windbg) to abort symbol loads that take too long.
Run !sym noisy before .reload to track down problems loading symbols.
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck BE, {fffff8800142a390, c00000003f79121, fffff88005db8940, b}
Probably caused by : ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+44cde )
Followup: MachineOwner
1: kd> !analyze -v
ATTEMPTED_WRITE_TO_READONLY_MEMORY (be)
An attempt was made to write to readonly memory. The guilty driver is on the
stack trace (and is typically the current instruction pointer).
When possible, the guilty driver's name (Unicode string) is printed on
the bugcheck screen and saved in KiBugCheckDriver.
Arguments:
Arg1: fffff8800142a390, Virtual address for the attempted write.
Arg2: 0c00000003f79121, PTE contents.
Arg3: fffff88005db8940, (reserved)
Arg4: 000000000000000b, (reserved)
Debugging Details:
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT
BUGCHECK_STR: 0xBE
PROCESS_NAME: System
CURRENT_IRQL: 1
ANALYSIS_VERSION: 6.3.9600.17237 (debuggers(dbg).140716-0327) amd64fre
TRAP_FRAME: fffff88005db8940 -- (.trap 0xfffff88005db8940)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=fffff8800142a390 rbx=0000000000000000 rcx=fffff8a010fa38c0
rdx=fffff8a0037207b0 rsi=0000000000000000 rdi=0000000000000000
rip=fffff880016ba167 rsp=fffff88005db8ad0 rbp=fffff80003236280
r8=0000000000000000 r9=0000000000000009 r10=0000000000000004
r11=fffff8a0037207b0 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei ng nz na pe nc
Ntfs!NtfsCommonClose+0x1e7:
fffff880`016ba167 488908 mov qword ptr [rax],rcx ds:fffff880`0142a390=83485708245c8948
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff8000310e7c6 to fffff80003090bc0
STACK_TEXT:
fffff880`05db87d8 fffff800`0310e7c6 : 00000000`000000be fffff880`0142a390 0c000000`03f79121 fffff880`05db8940 : nt!KeBugCheckEx
fffff880`05db87e0 fffff800`0308ecee : 00000000`00000001 fffff880`0142a390 fffff8a0`03632300 fffffa80`060e2010 : nt! ?? ::FNODOBFM::`string'+0x44cde
fffff880`05db8940 fffff880`016ba167 : fffffa80`060e2010 fffff800`03236280 fffff8a0`03720680 00000000`00000009 : nt!KiPageFault+0x16e
fffff880`05db8ad0 fffff880`0170cd32 : fffffa80`060e2010 fffff8a0`037207b0 fffff8a0`03720680 fffffa80`03f42180 : Ntfs!NtfsCommonClose+0x1e7
fffff880`05db8ba0 fffff800`0309a261 : 00000000`00000000 fffff800`03387c01 fffffa80`07073b00 00000000`00000011 : Ntfs!NtfsFspCloseInternal+0x186
fffff880`05db8c70 fffff800`0332c73a : 00000000`d2235aa9 fffffa80`07073b50 00000000`00000080 fffffa80`036cd740 : nt!ExpWorkerThread+0x111
fffff880`05db8d00 fffff800`030818e6 : fffff880`009eb180 fffffa80`07073b50 fffffa80`036f9660 00000000`00000000 : nt!PspSystemThreadStartup+0x5a
fffff880`05db8d40 00000000`00000000 : fffff880`05db9000 fffff880`05db3000 fffff880`05db89a0 00000000`00000000 : nt!KxStartSystemThread+0x16
STACK_COMMAND: kb
FOLLOWUP_IP:
fffff800`0310e7c6 cc int 3
SYMBOL_STACK_INDEX: 1
SYMBOL_NAME: nt! ?? ::FNODOBFM::`string'+44cde
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
IMAGE_NAME: ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 53b9f073
IMAGE_VERSION: 6.1.7601.18526
FAILURE_BUCKET_ID: X64_0xBE_nt!_??_::FNODOBFM::_string_+44cde
ANALYSIS_SOURCE: KM
FAILURE_ID_HASH_STRING: km:x64_0xbe_nt!_??_::fnodobfm::_string_+44cde
FAILURE_ID_HASH: {a16fedb0-3e79-665d-fa99-475fc0f2a4bc}
Does this make any sense?
kreja
But latest batch of 4x2GB crucial ram was working fine till I replace the PSU wor... I forgot to mention my last batch of Kingston ram keep frying due to bsod and reboot until I RMA till sianz...
blue00
not enuff power
Passer
i believe psu can cause a lot of weird problems.
Personal experience, long long time ago, my com keep getting bsod while playing Battlefield 1942.
Troubleshoot like mad from software to gfx card to mobo etc... end up is psu. -.-" least expected but once changed, no more bsod. So yeah just saying.
kreja
Thanks for sharing.
I suspect its my psu but I don't have exact proof of it.
Here's the history of my problem (since 2008)
I started out with this setup:
Q9550 + Gigabyte GA-EP45-UD3R
2 x 2gb ddr2 800 Kingston CL5
WD 640GB Black (PCT)
Enermax Pro 82 625W
(2010)
then I added 2 more 2gb ddr2 800 Kingston CL5 and things start going weird...
Sometimes bsod, sometimes cant boot up.
I ran memtest on all 4 ram, at different slots, all no problem.
Usually I just try to reslot them, they'll work fine for a while.
but after awhile all the bsod, rebooting will fry the ram.
I'll have to rma them.
(2012)
Then I upgrade gfx card to palit gtx460, and bought a seasonic psu x760w.
I mess around with the ram voltage settings, but i just couldn't get the system to stablise.
Then I bought 4x2gb CL6 Crucial ram to try out. Everything seems fine till I recently cannibalised the seasonic psu for my new rig, replaced it with my old enermax one.
Now I'm unable to run 4 sticks of ram together. I swapped back my seasonic psu. Nothing works, I cant boot to bios screen at all.
Ran a quick memtest on all slots and ram, no problem.
well technically I dun really need my old rig. But I'm just curious to find out whats wrong lol... psu problem? or ram problem?? or mobo can't support 4 sticks? Abit lame, mobo give me 4 ram slots, I can't use them all?
Anyways just sharing to see if any bros here share similar problems.:s12:
FinalTidus
Thanks for sharing.
Enermax Pro 82 625W
(2010)
(2012)
Most prob is PSU already... Better get a new one.
