Power cord replacement
jtjt00
TS, you better off going to Sim Lim Tower with existing adapter and find one with same voltage/current/tip?
snorex
Thanks, will try to make it down but hard to fine the time to do this.
"Output Adaptor Jack size : 5.5mm x 2.5-2.1mm Compatible"
Thanks, but is there an easy way to tell what the jack size is for my Xiaomi power cord?
I checked the specs page for my model (https://www.mi.com/global/mi-23.8-desktop-monitor-1c/specs/) and it didn't tell me what is the jack size.
wtfh4x
You will have to bring the old one and eyeball the difference or measure it with a ruler. Usually these specs are not provided.
snorex
Thank you - now I understand why one of the users said I had to go down to Sim Lim.
Koenig168
you can place a ruler across the output jack for your XiaoMi power cord to determine it's inner and outer diameters.
snorex
Thanks. Can I confirm, if the specs on Shopee says "Output Adaptor Jack size : 5.5mm x 2.5-2.1mm Compatible",
That means,
A = 5.5 mm
B = 2.1 mm (diameter of small circle)
C = 2.5 mm (diameter of big circle)
Am I right?
Koenig168
That means,
A = 5.5 mm
Am I right?
C = 5.5 mm
B = 2.5 mm
The other size for B is 2.1 mm but this does not seem to be the case from your pic. The Shopee specs probably meant that a pin designed for 2.1 mm hole will also work with the adapter which is 2.5 mm.
Phen8210
That means,
A = 5.5 mm
Am I right?
C = 5.5 mm
B = 2.5 mm
From what you two said, it seems like the inner diameter is the same, just the outer diameter is different, that's why can be 2.1-2.5mm. Must confirm with the seller.
And if that is the case, your socket can fit an outer diameter of 2.5mm?
