Power supply or GPU problem?
spiky0180
Seasonic or superflower. One distro at ang mo kio, the other at chai chee.
Evga also ok. Same distro as superflower.
Informant
Can ask which recommend shop is really good for purchasing their power supply? Superflower most of the shop don’t sell it.. please no tradepac as I bought their item always can’t last for 1 year.
ZrE0_Cha0s
den can go over to PCT/Dynacore to get seasonic new series psu (cant rmb the name :p)
tmfwy
Hey guys, i've another quesiton.. idw to create additional thread to keep filtering other threads.. Can anybody suggest me what good power supply to use? With local warranty instead of international warranty. if possible don't want distributor from banleong as their working hours is only 6 hours tried to rma from them they off work quite early also 5pm close but 4.40pm office light off already.. Which type of power supply is easier for cable managing semi modular or fully modular is easier?
Buy Convergent PSUs from Infinity...
Informant
This thread abit outdated.. i got a minor question. issit possible to send my power supply through oversea for RMA from singpost? If the staff ask whats the good inside what should i say?
Koenig168
Sure, but should be quite expensive since PSUs are heavy. Just declare as computer power supply.
Informant
Last year i did rma once i declare its computer power supply. but this year idk cos their policy has been changed
could be MB problem? gpu fan running?
the gpu light itself already on le, then the fan run. i did a motherboard jump power switch multiple times it work.. with the same power supply.. like immediately. what is the likelihood that the casing power button problem? i did a minor test need to press quite hard then will power up
Neptunes43
You might want to try isolating your system such as running your pc outside of the case, checking the wirings and its conditions (is it pinched/damaged) outside of the case. That way, you can get the answers you'd need.
If things are fine outside of the case, then perhaps something is indeed wrong with the case. Hope things will turn out fine for you!
Informant
The problem is really frustrating, spend about $150($60 Send back to the country for replacement of PSU, $80 Send for cleaning service + cable managing) to fix/find the issue but still same situation like last year.. Ask the person in sim lim that clean my casing about the issue wanna charge $30.. Daytime really hard to power up as there's quite a number of delay after pressing power button.. End of the day power off and try power up no delay at all..
Sorry i got 0 experience for making my pc outside of the case..
They put straw on my wallet already.
Smurfy
Everything works fine if u can on without power switch than it the switch faulty.
Informant
Fresh power up of the day:
https://youtu.be/wSZcRxKgDqY <-- this one got problem
Shutdown and try power up again:
https://youtu.be/ViZtyiZVAyQ <-- quite bad until i have to hold the power button..
About 4-6 hours later after power up of the day:
https://youtu.be/ApNKXBQLn6M <-- this one should be normal
Can some one conclude for me base on the video? Due to lack of time i'm not able to disassemble everything out from the casing..
All the Youtube links are dead.
working now...
kracie17
from the look of it, i suspect its the power supply issue. could you list down your specs like others on the right?
Informant
Have you replace your CMOS battery with a new one yet? Cost $1-2 dollars. Just go replace it.
https://steamcommunity.com/discussions/forum/11/618460171318429760/
What issit gona do with it? I thought that only reflect on date and time only? And yeah, got a very minor issue with the date and time.. everyday power up will have a time delay of 2-3second and monthly I have to add up a minutes to match with the world local clock..that one don’t really affect me. Most affecting me are the power on issue ._. .. if you say CMOS battery, any type of cmos battery will work?
Based of the link, I don’t have immediately power off cause by the psu..
