[Printer] Laser Printer questions lip lai !!!
heydude
Hi
am looking for a multifunction color laser that has the following features
a. small footprint
b. home use
c. color laser or LED (any difference)
d. network print and network scan
e. scan, print, fax, copy
any recommendations is highly appreciated.
tks
theToners
Hi
a. small footprint
b. home use
tks
Fuji Xerox CM205f.
You will never go wrong with Fuji Xerox when you are talking about colour laser.
Please note this model is SLED
ninja99
setting up wireless scanning is a hassle for Fuji Xerox CM205fw. anyone can help on error 031-529?
nobrain1
hi bros,
i'm using Fuji Xerox CM205f. still under warranty. will using oem compatible toners void the warranty?
theToners
You may want to try to call their customer service, 1800-356-556. Not much people technical enough to answer your question.
F1ngolf2012
Fuji Xerox CM205f.
Hi Daimen,
Are there models from HP and Brothers with similar features to Fuji Xerox CM205fw and CM205b ?:s11:
F1ngolf2012
Hi ninja99,
I'm considering to buy CM205fw. Is the hassle on wireless set up only on scanning ? What about wireless printing ? Beside the hassle on setting up wireless scanning, do you face other issues ? :)
theToners
Hi Daimen,
Yes.
For Fuji Xerox CM205b it would be HP M175nw Retail $629
M175nw Printing speed 4ppm only for colour* Please take note
For Fuji Xerox CM205fw, it would be HP CM1415fnw Retail $749(I may be wrong)
SeaDweller4K
Hello all, any recommendations for the following (indication on prices would help greatly):
Printer A
1. Colour laser printing
2. Print/fax/copy/scan
3. Duplex capability (manual or automatic)
4. Can print on A5 and cheque-sized paper
5. Wireless/network printing capability
Printer B
1. Black (mono) laser
2. Print only
Thanks in advance.
theToners
Printer A
Printer B
2. Print only
Thanks in advance.
For Colour, I would recommend you Fuji Xerox CM205f ( AIO with network ) or CM205fw ( AIO with wireless ).
It is manual duplex.
For the mono printer, I would recommend you brother HL-2240D. It is auto duplex.
Both got A5 as an option as for cheque size, you could customise it if they dont have the option.
SeaDweller4K
Thanks for your input theToners. I just bought the CM205fw today and will test out the functions before I post more questions.
cnt
any feedback for fuji xerox cp205w? wat is the best price? :s42:
F1ngolf2012
Hi,
A friend of mine used to struggle in setting up the wireless function. Would like to know if you have any issues setting up the wireless function for your CM205fw as I intend to buy the same model. Thanks.
EquinOoX
hi guys i just bought brother 2270 model, using duplex the first time, found that the printing on duplex is uneven. Is it normal? I mean the duplex side is printed higher that the first side............thank u
Ulupandan
Hi,
I'm using same model, wireless setup is easy, using printer's control panel, no need to connect to pc. Navigate to network setup, enter the "ssid", choose wep/wpa2/etc, enter "password" & printer will connect to wireless network. Just place printer near to router during initial setup, to get proper signal strength for connection.
SeaDweller4K
Yup it was relatively simple. The printer will restart automatically and you can subsequently see the wireless icon appear at the top right hand corner. Of course you will also need to run the installation software on your designated PC/Laptop.
Have yet to try the "scan to PC" function though. Wonder how it will work if there are multiple PCs - will there be a selection of IP addresses?
xK3lViN
Hello, need advice for a new laser printer.
I would prefer:
1) Duplex
2) Mono Color
3) If possible, scanning
and of course, a budget of less than 200 :)
I have saw Brother HL-2270DW is this model good? Or is this brand good? Thanks in advance :)
theToners
I would prefer:
1) Duplex
2) Mono Color
You could look for Brother DCP-7060D.
PRINT SCAN COPY (Usb connection)
For HL-2270dw, it does not have scanning but it has wireless. Both less than $200 so it depends if you need scanning or wireless more.
These series of mono duplex printers from brother are very popular.
xK3lViN
hmm .. thanks! Is this model good? MFC-7360
are there also any other brand that is good?
