[Printer] Laser Printer questions lip lai !!!
theToners
Anyone with laser printer questions can come in and ask !!
Currently in the market the top 3 brands are Fuji Xerox, Brother and Samsung.
List the specs of printer that you are looking in this way so hwzers can assist you better!
1. Mono or Colour
2. Print, Print Scan Copy (3in1) or Print Scan Copy Fax (4in1)
3. Printing capacity per month
4. Budget
5. Other extra requirement like wireless, iphone printing etc.
Cheers !!
almcxy
which model and price can perform the following:
1. colour printing
2. auto duplex /ADF for printing, scanning, copying and faxing
3. able to do PC fax and scan to network folder, fax to network or email
4. wireless
5. low tone / cartridge price <$25 per ink cartridge /2,500
6. reliable
Pokémon
Don't get Samsung.
Bad smudging after less than 3 months for mine, and only way seems need to change all the toners.
My colleague bought during the last IT Show, had the same problem, and was also told many similar complaints for those who bought then.
theToners
1. colour printing
Fuji Xerox CM305df or Samsung CLX-6220FX
Both an PC fax but is outgoing only. Both also can scan to network folder or email. Cannot fax to network or email.
4. wireless
No wireless but have network so have to connect to wireless router to make it wireless. You have to decide wireless or duplex more important.
Toner for CM305df:
Black 3000 $112
Cyan 3000 $165
Magenta 3000 $165
Yellow 3000 $165
(we got compatible toners)
Toner for CLX-6220FX
Black 5000 $115
Cyan 4000 $135
Magenta 4000 $135
Yellow 4000 $135
(we dont have compatible toners)
6. reliable
Fuji Xerox would be more reliable
Hope that this is helpful for you.
almcxy
I am using HP 8600 A plus that does all the above and looking to upgrade. Ink cartridge for black is $30 for 2,500. Is that any model that can replace that ?
storm913
Looking for one:
1. Mono or Colour
Mono
Print only
About 500 - 1k pages per month
4. Budget
As low as possible
Best if can have auto duplex, or at least, easy to print both sided.
Thanks man!!
loneranger55
How come no one mentioned Canon ah? Not good ah?
Anyway, any suggestions for:
1. Mono
2. Print, Scan, Copy (3 in 1)
3. Student usage (low?)
4. Budget (not more than $200-300? enough?)
zymphurious
Need advice on printers! Mum need a printer that can print photos on A4 size paper. Used to use Canon inkjet in the past, but print heads always get clogged, and need special photo paper to print, else color very washed out. So am considering laser printer.
Photos are of products, will be laminated after printing out, and then pass to salesman to distribute out.
1. Color
2. Print only. Actually if got print+scan will be good, but normally these multifunction printer, scan quality is not that good right?
3. Printing capacity per month: average 40-50 photos on A4 size paper at least, when got new products come in, can hit to 200 plus.
4. Budget: Most value for money ba.
5. Other extra requirement: I am more concerned on the cost per page overheads, as most printers' toners advertised quantity is just based on 5%. So wondering, for a full toner capacity, on average, for my type of use, one toner can print average how many photos?
I have been looking around the forum and is considering Fuji Xerox latest SLED printers actually, with the plus of having compatible toners. But have not seen the actual printout of photo quality of the their color laser printers, so not sure if it is good enough a not for my mother.
And lastly, is considering laser printer better? Or should I go back and include inkjet printers too? I don't need very very good quality photo printout. But at least must be true to color, and look decent like a photo (instead of pixelated digital color printout).
Thanks!
playplay
Some feedback on the below 2 brands of AIO laser printer i used.
Samsung scanning is quite ok, color smudges. Need to call technician down to change drum.
Fuji Xerox printout is good, scanner quality is very bad even though can set up to 600dpi but quality is like 200 to 300dpi only. very grainy.
theToners
Hi, sorry for laser there is no model that can replace. However for ink, the page yield is not true page yield as it would dry up. Probably if you still want those printer with all the functions, you have to use or buy back hp 8600 A plus.
theToners
Looking for one:
1. Mono or Colour
Mono
Print only
Fuji Xerox P3435d $283 or Brother HL-2240D $148 or Samsung ML-2955ND $238
All three have auto duplex.
If you want easy to do manual duplex you can go for Fuji Xerox P205b $89 for last it show.
All can match your printing load. So probably I will explain their consumables.
Fuji Xerox P3435d Auto Duplex
Toner + Drum combine together.
Standard yield 4k pages @ $145
High yield 10k pages @ $350
Fuji Xerox P205b Manual Duplex
Toner only as drum is inbuilt into printer and covered by 4 years warranty.
Standard yield 1k pages @ $55
High yield 2.2k pages @ $95
Brother HL-2240D Auto Duplex
Toner
Standard yield 1.2k pages @ $54
High yield 2.6k pages @ $92
Drum 12k pages @ $98
Samsung ML-2955ND Auto Duplex
Standard yield 1.5k pages @ ? Forget pricing already
High yield 2.5k pages @ ?
4. Budget
As low as possible
Thanks man!!
Hope that this is helpful !
theToners
Cause canon warranty 2 years only. Toners also expensive.
Canon MF4412 $199
Warranty 2 years
Toner + drum combine
Standard yield 1.6k pages @ $99
1. Mono
Fuji Xerox M205b or Brother MFC-7055
Fuji Xerox M205b $179
Warranty 4 years carry-in.
Toner only as drum inbuilt into printer can covered by the warranty.
Brother MFC-7055 $158
Warranty 3 years on-site
Toner
Standard yield 700 pages @ $32
Drum 12k pages @ $148
Hope that this is helpful. For toner prices +- 5% cause depends on reseller discount also.
theToners
1. Color
Thanks!
Dont have to look at other brands of colour laser already. In the market, Fuji Xerox SLED printers have the best quality printing for photo. The rest is crap.
However, for laser printer, they cant print borderless photos so will have a small margin at the side. Laser printer is confirm better just that you have to see if the Fuji Xerox quality is alright for your mum. :s13::s13:
HW_FAN
Fuji Xerox covered by 4 years warranty? It is 2 + 2 warranty, 3rd and 4th year need to pay labour cost depend on your model.
theToners
Correct. However the labour cost is $60 for on-site (applicable only for models with on-site warranty) or $30 for carry-in. Parts and drum all covered under the 4 years.
hondafreak
Hey guys, will be looking for a AIO printer in this PC show. Would be great if someone will recommend me some options.
Specs that i would need include:
1. Full duplex printing
2. Colour printing
3. AIO capabilities (Scanner Copier Printer)
4. Cheap aftermarket / 3rd party ink options
5. Wireless would be a bonus
5. <$250
Currently im looking at the Brother DCP-J725DW but other recommendations would be great. Thanks. :D
