[Printer] Laser Printer questions lip lai !!!
ak6110
List the specs of printer that you are looking in this way so hwzers can assist you better!
1. Mono or Colour
Color will be good
2. Print, Print Scan Copy (3in1) or Print Scan Copy Fax (4in1)
4 in 1, doc feeder will be good
3. Printing capacity per month
At least 200 copies
4. Budget
$300 to $500
5. Other extra requirement like wireless, iphone printing etc.
Network is required, good to have, support mobile printing
Cheers !![/QUOTE]
theToners
1. Mono or Colour
Color will be good
At least 200 copies
4. Budget
$300 to $500
Cheers !!
[/QUOTE]
You can consider Fuji Xerox CM205f.
Print Copy Scan Fax with Network
supports mobile printing as well when u connect it to your rounter to make the printer turn wireless.
$599
2 + 2 years warrany.
theToners
Hi, any colour laser printer that can print on 300-360gsm paper? Manual feeder is fine. Thanks :)
Fuji Xerox C5005d bypass tray- 280gsm machine $5699 retail
Fuji Xerox ApeosPort - IVC7780 bypass tray - 300gsm machines $40,000 retail
Both can claim PIC Grant
couch.potato
Hello, don't know if you can help me on this one:
I need a COLOUR laser printer (already have a Canon Mono AIO) for printing text-based stuff like wedding invitations and quotes for framing on cardstock paper (probably not exceeding 260gsm, but max 300gsm). Small business requirement because Singapore (outsourced) printers are way too expensive and have no Pantone matching system.
Purely printing only. Probably minimal graphics/photos (say, 80% text, 20% graphics). Hoping to have wireless function.
Budget is under $500. But willing to rent from Canon/Fuji/Sharp the office humongous kinds if you have recommendations.
Already read a few reviews on Samsung's lower range ones ($229-$259) and saw that printing quality is already good enough (semi-gloss photos)! So I suppose higher end ones are even better?
Thank you! :)
theToners
Thank you! :)
Which Samsung Laser that you read about so I could have a better understanding??
You mean monthly budget $500 right?
For faster response, you could email me at damien.printcasa@gmail.com
[for retarded mods] I AM NOT ADVERTISING AS I DO NOT SELL PRINTERS JUST HELPING A FELLOW FORUMER REGARDING HIS PRINTING NEEDS
DO NOT GIVE ME INFRACTION OR BAN FOR THIS.
baiyihao
Hi all, would like to get some comments for the following:
1. Mono or Colour
Mono
3 in 1, doc feeder will be good
At least 500 copies ~ 5 cents per print would be nice
4. Budget
$250 to $350
auto duplex
Saw the Brother MFC-7860DW, was wondering if there are cheaper ones without wireless capabilities
Thanks!!
Dadgis
Anyone have problem with FX CM205f/fw scanning doc to a mac? no issues with PC but mac just say login failed. Try with different macs also cannot. Simplified login name and password also dun work. thanks.
Sim Kai Long
Hi theToner bro, I'm looking for a printer that is reliable and meets the following criteria.
1. Mono
2. Print Scan Copy (3in1)
3. Approx. 200 per month or more.
4. Under $450
5. Wireless is needed due to place printer is to be placed at. AirPrint would be a bonus, not needed though.
Thanks in advance.
tonerseller
1. Mono or Colour
Mono
4. Budget
$250 to $350
auto duplex
Thanks!!
Dont have leh if you want cheap running cost. If you you can consider Fuji Xerox M255z now $399 + $100 ntuc vouchers after offset = $299 only.
Have all the same functions and wireless as well. Unless you dont need auto doc feeder (ADF) and usb connection then can go for Brother DCP-7060d. $188
tonerseller
You could try to contact their customer service hotline to check it out :s12:
tonerseller
1. Mono
4. Under $450
Thanks in advance.
Woah this one idk where to start from.. got so many options with your budget
Not gona recommend samsung cause of their ****ty toner cost and poor reliability. No offence if you are a samsung fan as it is base on my and other customers options :s13::s13:
Canon MF4720w $199
Print, Copy Scan (wifi) (No auto duplex printing)
Toner
$105 2.1k page yield
1 year on-site/carry-ing (not sure but cfm is 1 year) warranty
No document feeder so you may have problems doing multipage to 1 pdf file scan
Fuji Xerox M205fw $349 +$100 ntuc vouchers
Print,Copy, Scan, Fax(ignore if you dont use fax) (wifi) (No auto duplex printing)
Got ADF so can do multipage to 1 pdf file and auto scanning with ADF
Toner
$55 1k page yield
$95 2.2k page yield
2+2 years on-site warranty
Brother MFC-7860dw $348 + x mini speaker? lol (Got apps to print from iphone and android)
Print, Copy, Scan, Fax(ignore as well) (wifi) (AUTO DUPLEX PRINTING)
Toner
$54 1.2k page yield
$92 2.6k page yield
Drum(only brother special need to change this)
$98 12k page yield
3 years on-site + 2 years carry-in
Fuji Xerox M255z $399 + $100 ntuc vouchers (basically functions are similar to brother MFC-7860dw except this machine do not have apps to print from mobile phone and have nicer print out quality)
Toner
$105 2.5k page yield
$180 if buy 2 together in one packaging
Sim Kai Long
Canon MF4720w $199
Toner
Toner
$55 1k page yield
$95 2.2k page yield
Toner
$54 1.2k page yield
$92 2.6k page yield
$98 12k page yield
Toner
I'm leaning towards the M255 z as having duplex printing would be useful when I enter university (printing of notes). where should I look to purchase one?
Gixxer1000
Hi, please recommend
1. Mono
3. Low volume printing. About 50 pcs a month
4. 200 - 300
5. Duplex printing, wireless preferred and good printing yield
tonerseller
1. Mono
4. 200 - 300
Same thing as the fellow former below.
Bobian u have to go for 4 in 1 if u die die want auto duplex
Toner
$54 1.2k page yield
$92 2.6k page yield
$98 12k page yield
Toner
Gixxer1000
Toner
$54 1.2k page yield
$92 2.6k page yield
$98 12k page yield
Toner
Thanks. If manual duplex eh?
tonerseller
IF manual duplex and dont need ADF,
Canon MF4720w $199
Toner
Toner
$55 1k page yield
$95 2.2k page yield
That if you die die want wireless.
If you dont mine using USB connection, you can get for this model
Brother DCP-7060D (Auto Duplex)
Print, Copy, Scan
Toner
$54 1.2k page yield
$92 2.6k page yield
$98 12k page yield
