royfrosty
- Jul 23, 2009
Looks nice, what spray you use, can give me the brand and code number?
Where u buy?
Did you spray primer before you spray the red colour? Then how come can peel off? Abit blur here..lol
Its called Plasti Dip. Google plasti dip Singapore. Its location is at kallang way industrial.
Basically this paint is unique. It can be removed if you do not like the paint job. Its rubbery matte feeling.
I did not spray any primer. Cause of its compound, it is able to stick on any surface. If you do not like it, you can just peel it off.
