aLpHa-Ev7
- Jan 1, 2000
Do you guys think a 0.84 F VS2 princess cut(square modified brilliant) Ex polish, VG symmetry, that cost $4k is cheap?
Wow that sounds too good to be true. GIA certified?
really envy u guys ,really got alot $$$ to buy diamond rings ...my wedding ring was only $600+ (gold without DIAMONDS !!) ..that was 16years ago ...
Yes it is GIA certified. seems like a good deal to me!
The price is correct for a Princess Cut... Princess cut diamonds are usually much cheaper than the Round diamond..
Just make sure it has no fluorescence!![]()
Same carat size, clarity and colour...is round or cushion more expensive? provided same heart n arrow cut
anyone can advise how a cloud clarity will affect the entire performance of the stone ?
As long as its eye clean, it won't affect the performance of the stone
Hi, went to JP.
Was quoted $8900 for solasfera 0.73c, vs1, e.
I thought its a bit overpriced. Can I have some comments? Thx.
Hello
anyone here got the engagement ring re-sized with JannPaul?
How long will they take to do it?
Hi, went to JP.
Its quite fast... they resized mine in a few days.
