Proposal Ring - Part 2
lowchia
I received mine too.
Akai Ryu
need some help here. how is this spec?????
cushion cut AGS
0.832
E
VS1
abt 9k plus
FortyFive
How much were you guys quoted for the ring settings at JP?
With side diamonds:
Without side diamonds:
aLpHa-Ev7
Do you meant the triangular white parts on the girdle?
That's fine.. That's how a classic girdle is suppose to look like
Thanks mate. Jann from JP has responded that via email, highlighting the difference between painted girdle, classic girdle and dugged girdle. Top stuff.
Grizz.P
hollander
Tx.. I read like 50 pages liao... and have a better idea.. slowly reading the older posts... reading too many at one go just gives me a headache :s22:
What's the average size that people get? Or is it a budget and preference thing?
Merfmerf have a very good point on that, see what your budget can do/have then slightly go backwards to improve the color, cut and clarity though the carat will be affected. Increasing the carat will affect cut, color and clarity ;-)
Then another one, What I can suggest is, as an example: Allocate 2K for the diamond then look for a 1.5K diamond and see what you can have on that budget, then you still have 500 to improve what you have ;-) its like 75%/25%, a bit small allowance but again will give a good adjustments later on ;-) you can even do 70%/30%. 60%/40% is not realistic anymore I think ;-)
Draculav
It's from White Dwarf. I am quite satisfied with the quality and ring design.Has any one tried them?
There was an old unpleasant review about them before. White Dwarf had an account on this thread posing as their own customer.. Admin has since banned their accounts. Think it was Des126 or something..
