Proposal Ring - Part 2
nomoreliaola
ya i get wat u mean ...
just dukoe if its ai wan coos they sell super ideal n i buying an ideal lor ..
u noe wat i mean
For diamond that size for super ideal..there are not many.. usually must wait for batches to come in .. not they don't want to sell u.. is don't have.. unless you can wait up.
This is what I understand from Aaron.
marlerocks
Need to seek expert advice here.
Am buying a diamond certified by GIA.
GIA
ROUND BRILLIANT
Measurements 6.20 - 6.25 x 4.01 mm
Carat Weight 1.00 carat
Color Grade F
Clarity Grade VS2
Cut Grade Good
PROPORTIONS
Depth 64.4 %
Table 59 %
Crown Angle 37.0°
Crown Height 16.0%
Pavilion Angle 40.8°
Pavilion Depth 43.0%
Star Length 50%
Lower Half 80%
Girdle Slightly Thick to Very Thick, Faceted, 5.5%
Culet None
FINISH
Polish Very Good
Symmetry Very Good
FLUORESCENCE
Fluorescence None
CLARITY CHARACTERISTICS
Clarity Characteristics Feather, Cloud, Indented Natural, Cavity, Pinpoint, Natural
INSCRIPTION(S)
GIA 5136198008
Was quoted about $10,700 and this includes the ring from a local jeweller.
Want to ask the forumers advice is this a reasonable price to pay?
Thank you very much.
Milo-Dino
1 Carat
Clarity Grade VS2
F Colour
Cut Grade Good
Polish Very Good
Symmetry Very Good
I think the experts here need to know the dimensions and the cutting... and if possible, scope pictures.
Dimensions if you got the GIA number, pple can search online for them.
marlerocks
Thanks BRO! i have edited my post to have more details! Hope forumers can give some advice as ii am very noob in diamonds
Lurker_13
I am afraid this may not exactly be a gd choice.
1. The girdle - The best girdle thickness is Thin, Medium or Slightly Thick. Diamonds with Thick, Very Thick, or Extremely Thick girdles weigh considerably more.
2. The Depth is too deep. There probably will hve more light leakage.
3. The table is kinda big
4. The crown angle too steep
5. The dossier does not show the location of the inclusions.
6. Have u seen the stone in person? Is the stone mounted?
7. Never get full carat diamonds eg 0.5,0.7, 0.9 or 1.0
8. Search on bluenile they hve similiar spec stones for $7k+ without setting. Whiteflash at USD 7k+ virtual stk without setting.
9. HCA is 4.3 - Good - Only if price is your main criterion
Lurker_13
Maybe you can share more info such as the specs of the stone, the scopes & the cert number so the bros here can better help advise.:)
Draculav
GIA
ROUND BRILLIANT
Color Grade F
Clarity Grade VS2
Cut Grade Good
PROPORTIONS
Depth 64.4 %
Table 59 %
Crown Angle 37.0°
Crown Height 16.0%
Star Length 50%
Lower Half 80%
Culet None
FINISH
Polish Very Good
Symmetry Very Good
FLUORESCENCE
Fluorescence None
INSCRIPTION(S)
GIA 5136198008
I agree with Lurker_13.. The diamond is not a good choice.
My super ideal cut is a 0.91 F VS2 is already about the same size as your 1ct diamond and even cheaper.
The measurement is 6.19 -6.21 X 3.83.
elnos86
Has anyone seen the actual Verragio rings from JP yet?
If yes please post some pics. pretty cool stuff
tomicaguy
Decided on this diamond. Got HCA1.9
Measurements 4.86 - 4.89 x 2.99 mm
Carat Weight 0.43 carat
Color Grade E
Clarity Grade VS1
Cut Grade Excellent
Depth 61.4 %
Table 58 %
Crown Angle 36.0°
Crown Height 15.5%
Pavilion Angle 40.6°
Star Length 50%
Lower Half 75%
Girdle Medium, Faceted, 3.0%
Culet None
Polish Excellent
Symmetry Excellent
Fluorescence None
Clarity Characteristics Crystal, Cloud, Needle
clock_ED
Fellows, am searching for Wedding Band... Has anyone tried vivodiamond? If yes please help to post some reviews. :)
Their price seem attractive though.
As for JP, any idea if they focus on Proposal or Wedding Band?
Saw the goldheart celestial series and they cost 6-8k, am thinking if JP's will be better priced.
UpperCut
Hmmm... Thot JP only sell Super Ideals never Ideal diamonds. Who is the staff tat served u at JP?
It's interesting I got recommended an ideal diamond as well. Just like you previously I didn't know JP sells Ideal diamonds too
Carnesir
jann paul is where?
how u all derived your budget ah?
i am thinking max 2 month of take home pay.. ok or not? lol
nomoreliaola
some pics ..
stone cost around 8k+
Measurements: 6.09 - 6.12 x 3.70 mm
Cut Grade: AGS Ideal 0
Color Grade: AGS 1.0 (F)
Clarity Grade: AGS 3 (VS1)
Carat Weight 0.825
Light Performance: 0
Polish: Ideal
Symmetry: Ideal
Table: 54.7%
Crown Angle: 34.2
Crown Height: 15.4%
Girdle: Faceted, 0.7% to 3.2%
Pavilion Angle: 40.6
Pavilion Depth: 42.8%
Star Length: 49%
Lower Girdle Length: 76%
Total Depth: 60.6%
Culet: Pointed
HCA: 0.6
UpperCut
some pics ..
Carat Weight 0.825
Polish: Ideal
Symmetry: Ideal
Table: 54.7%
Crown Angle: 34.2
Crown Height: 15.4%
Star Length: 49%
Total Depth: 60.6%
Culet: Pointed
HCA: 0.6
I see a prominent leakage at the 11oclock position.
But it's likely because of this little flaw your diamond is at least 1k cheaper than the super Ideal. It might be a blessing in disguise
Apart from that everything else looks good!
