Bros,
Any advice for investment-grade diamonds?
Thanks!
Very pretty stone you got there bro with very nice specifications!
But if you're seeking some critical points but small issues, the 7 o'clock heart has a clef and the distance between some of the hearts not even. But even with that.
Nice one bro!! =]
Thanks for the comments !
I'm pretty much new to diamonds as well and just got some rough knowledge here and there. May I ask on the comment on the distance between the hearts, is it just aesthetically flaws or in any way affect the diamond? What about the clef as well?
Hi there... IMHO, these are aesthetics and if you're not too particular, it's actually a great piece of rock! mind sharing the specs?![]()
Very pretty stone... Mind sharing the specs of the stone..
The hearts and arrow diamonds are created to create the brilliance and other stuff within the HCA tool. And this cut is demonstrated by the symmetry of light reflection created within the diamond.
As such the imperfections are a resultant on a slight flaw in the symmetry of light reflected in the diamond. You probably need a master cutter to give you the a very very good cut. But that would also remove a great deal of the diamond rough. Yours would be a great cut already! =] you can read about it from heartandarrows.com.
Anyway his specifications are within the HCA tool screen grab.
Paid the deposit and got my ring images; sharing it here with the bros. Any honest comments are welcomed!
Nice diamond bro! E color is in the Colorless range and the VS2 looks eye clean. Scopes looks very symmetrical too. You collected your ring yet?
before taking the plunge, will be nice to know what the more knowledgeable think of this...
Proportions
Depth 62.0 %
Table 56 %
Crown Angle 34.5°
Crown Height 15.0%
Pavilion Angle 40.8°
Pavilion Depth 43.0%
Star Length 55%
Lower Half 75%
Girdle Medium to Slightly Thick, Faceted, 4.0%
Culet None
Opinions anyone? Thanks in advance!
1.11 D VS2
Wah! $$$$ hahaha
Hmm this one the hearts like not very aligned at the 1 4, 5 o'clock. Personally I think not that ideal. Although the HCA tool brings back good returns.
I guess it depends on the price you are paying for it. But I would see if there are other diamonds.
hehehe
