Proposal Ring - Part 2
Lucask83
Any idea how big ussually is the engagement ring? Is it must 1 carat? And how much roughly should i spend on the diamond and ring? Any recomend for jewellery shop? Always see the discount at taka, but some of my friends say it is not very good there?
If ur gf small size u buy something big, I dare say it will look Not proportional and maybe people might think the diamond is fake? Anw I value quality over carat size. And a gd quality diamond, though not big, might shine more
fila_22
0.65ct F vs1
Clarity characteristics : feather
HCA 1.9
Or
0.56 E VS2 (from JP)
Super ideal
HCA shd be below 1.4
Price is about the same. Please comment
I read that feather can possible result in further fracture if not taken care properly.and not to get those with feather near the girdle. Does that mean I shd avoid those with feather in the clarity characteristic?
tk
2. It depends on your budget. Some people only budget for $2K while some $10K.
For those on tight budget, <$1k also can find diamond solitaire ring liao.. no need to overstretch finances by blindly following the crowd..
Lucask83
0.65ct F vs1
HCA 1.9
Or
Super ideal
Tough choice. But I think I will pick jp. Haha. And I think the carat is bigger yet same price cos color not as gd
tk
0.65ct F vs1
HCA 1.9
Or
Super ideal
assuming the 0.65 is a GIA triple ex, do take a closer look at it with scopes.. if the scope looks good and hearts & arrows looks good, then it could be the better buy.. after all, JP's super ideal is selected from good ideals..
beckslim
JP just uploaded a video comparison of Super ideal cut and Ideal cut. Difference is quite obvious.. Even the Ideal cut diamond have a lower HCA score 0.9
Goes to show, HCA score is not everything.
Lurker_13
The narrator dun sound confident... Still prefer Casey 😁
tk
it's a marketing video so take it with a pinch of salt.. they would naturally pick a upper end super ideal to compare with a lower end ideal..
shinyfong
Cut is most important when picking a diamond. Question is everyone say solasfera is all cut at a very strict standard so every solasfera cut grade is almost the same right? Therefore am I safe to say that we can leave out the cut factor when choosing a solasfera?
Sta5is
Hi all,
Can anyone help rate this diamond?
And i am caught between Solasfera and super ideal.
Thanks!
0.58ct E vvs2
JP Super Ideal
HCA: 0.9
ivandemi
JP cut standard are very strict. Solasfera is harder to cut.. so I assume the standards are more strict? If I'm not wrong, the Solasfera cert does not have cut grading as its a modified round. But you can still check the cut with the scopes. No harm checking the diamond with the scopes
ivandemi
Hi all,
Thanks!
0.58ct E vvs2
JP Super Ideal
HCA: 0.9
Tough choice bro... haha. Like the other bros have mentioned, see which one is more pleasing to your eyes.. Alot of bros here seems to be getting the Solasfera recently..
reitrac
For those interested, I find this website provides very useful information of diamond buying guide:
diamonds.pro/loose-diamonds-certified-diamond-prices
I may not agree with some of his view points (such as he doesn't recommend people to spend extra $ for excellent symmetry/polish), but I do enjoy reading his articles and discussions.
Hope this can help those who just start to search for diamonds.
lzjlee
Just went to JP n eclarity today.
Super ideal
0.527 F VS2 $3,800
0.51 E VS1 $4,150
Solasfera
0.53 E VS1 $5,300
Eclarity price is cheaper with similar specs. But no scope. N they claim that HCA is not recognised. How true is that?
alvismah
shinyfong ur diamond how much ? when did u make ur purchase? and how long they take to send u the scope images and cert ?
