quick question, does jannpaul accepts AMEX? intend to use my new AMEX true cashback for payment.
I think it's more like "why hasn't anyone bought it yet? Is there a catch?" kind of thing
Yes they do
They do take AMEX I just placed my deposit for my wife's new ring should be ready by the end of the month.
Do you guys think its ok for me to have a plain white gold wedding band while my hub wears the 916 yellow gold plain wedding band? Is white gold better or platinum better?
thanks for the info.
end of june u meannow is 31st May liao
I am exactly having the same issue! I like gold but my fiancée ring is white gold. So I got no choice I am going for 2 tones to at least match abit.. My mom says need to be a pair (personal opinion).
Basically
White gold: cheap, turns yellow over the time
Platinum: expensive, higher density (heavier / solid feel), actual colour
Mmmm but my husband is strictly wearing the 916 yellow gold and hates white gold lols!!! But I don't like yellow gold =( And I think it doesn't look that great when paired w my e-ring... dilemma!!!
Basically
We wear platinum wedding bands and ring is platinum setting too. We both hate yellow gold. I don't think it matters if the wedding bands are different you are two people doesn't need to be the same. Are the designs the same? why make them from the same material?
Why do you think white gold is cheaper? what makes a white gold ring cheaper? Unless you have a 24K gold ring (highly unlikely as it is too soft) then the gold content in an 18K white and 18K yellow gold ring are exactly the same? The main difference is the way they make the alloy for white gold vs yellow gold. If anything white gold settings are more expensive because they rhodium plate them after.
An 18K palladium white gold vs 18K nickel white gold vs 18K yellow gold have exactly the same amount of gold in them so the value is the same.
Hello!
Lynntoh was asking about White gold vs Platinum. In case you missed out something.![]()
Thats the reason I gave in to my fiancee. lol I must agree that gold doesn't really match well with the diamonds and her e-ring is in white gold too. Oh well..
If $$ is not an issue just go platinum but provided you like the weight else white gold is good too. If the white gold colour degraded, just go for polishing and replating, it is not an issue too.![]()
If you want to match his yellow gold band, you can consider those white/yellow gold mix band? It has both colors and might look more matchy
My e-ring is white gold w diamond.. think i'll just go with white gold plain band? If not gotta check out pricing of platinum. Got no idea about platinum at all
