Proposal Ring - Part 2
sugaricing83
Hahahaha it really depends on individual, to me, when I first received it, it looks really small to me. But now getting more and more used to it I find it still ok.
But I guess I will still upgrade in the end =P 0.458 and 0.46 no difference, roughly the same.
Or get another bigger diamond in future? I am aiming for that cos i see my halo setting bo hua to get a bigger size.
Lynntoh
hahahaha! cause I am that type whereby I will only wear one ring, so no point I get a bigger diamond and end up with 2 rings.... I rather upgrade =)
clarence.lye
if wanna pay by instalment, try uob.. uob is good cos every quarter if u spend $300 per month for 3months. u will get back $30.. this included INSTALMENTS..
next tier will be $800 and $1500..
if ur ring cost 4k.. u divide by 12 also hit tier of $300 liao... $30 + $30 + $30 + $30.. rebate $120 already.
i just applied amex because of the 5% rebate but no installment.. if not iwill go for manhantton 3% rebate
i already got a uob 1card that i used for my insurances & other fixed payments, so already hit the $1500 tier.
guess i can only go for either mahattan/amex (but no installment eh?) :vijayadmin:
i'm going for amex so not paying installment.. so just going to swipe once. 5K - 5% rebate. remaining - 1.5%. find it troublesome to get two cards.
clarence.lye
hmmm okay.
anyone here knows how much additional needed to top up if i opt for platinium instead of the 18k w.gold from JP?
I think scb should be able to do instalment but will not have any rebates..
Need to check with jannpaul whether they accept scb for instalment
Lynntoh
Not too sure if i should upgrade rhe diamond, any opinions? Basically i will be paying for the difference for rhe diamond and an additional topup of $250 for the new ring setting cus of prong issues.
Below are the prices i have to topup. Is it worth it?
Sent from Samsung SM-N910G using GAGT
cupidsux
nope, since your intending to upgrade then might as well just save up more to upgrade to a higher carat like .7 or 1.01, cause i feel that there isnt much difference in .3 to .5, no point doing slight upgrade while paying additional for setting T_T...
+ hint hint your hubby can already de la , dont worry lol
Lynntoh
Mmm!!! U have a point there! Ok i shall save up more for a 0.7 then! Or maybe between 0.65 to 0
69 haha
