kaysee
- Apr 18, 2008
Thanks! I actually went down for an appointment and was shown some diamonds.
Amanda, the owner seems to favour Carat > All else. She disregards Cut and says that Carat/Color is the first thing that ladies see and discern the most.
I told her that I wanted to view ASET scope images and she also mentioned that ASET scope was over marketed, together with the importance of cut.
Initially went to JP and was educated that CUT was king followed by Carat/Color/Clarity.
Right now I'm facing a dilemma because I can get a bigger Carat at Clarity for my money, versus what i can get at JP.
Any bros can get advise?
It seems like you're leaning towards getting a bigger carat for your budget. All depends what you want. If u feel that u can get a bigger carat at eclarity then go ahead. Of course u shld get them to find a diamond that is not of lousy cut and doesn't look bad under scope. You tell them the specs u want, they find for u, u pay money. Don't think it's that hard for them. Like I say, my friend's diamond of that specs I mentioned is really bling.
